Question on pot sizes...
Hi,
I couldn't find an answer to this an am wondering: what dictates increasing pot size from 250k to 500k? Is it just the fact of going to hum/mini-hum, or is a factor of the pickup resistance? Thanks! |
One more thing to double check with POTS.
With them being 250k rated, double check them: I have seen 250k pots when tested with a DC Ohm meter read, 225k-280k. They are with in a certain tolerance. You can check them and if you have one that tests at 225k you could switch it to one that tests at 250k or 270k. It's tricky how this is. |
Some Fenders came with 1M pots (like my '69 Thinline RI). After much experimentation, I've found that 250k volume and 1M tone works pretty well for me, even with a humbucker at the bridge. YMMV - it's all about your ears.
According to my wife, "the true beauty of free will is that you can continue to be stubborn" |
#7 (permalink) | |
![]() _____________________________________________ confucius said: man who want pretty nurse, must be patient. |
#8 (permalink) | |
Not tricky at all. All electronic components have a tolerance. A tolerance of 10% is not unusual for a pot. Your 225K measurement indicates it was 10% lower than the nominal 250K value. Not unexpected and nothing to worry about really. For a pot used as a volume or tone control, the exact value is not very critical. |
#11 (permalink) | |
Gibson originally used 500K for both volume and tone, for humbuckers and P90s. These days, Gibson uses 300K for volume pots, in their production (non-Historic) guitars. 500K pots with P90 pickups have always worked for me. If the guitar happened to be particularly bright, and a P90 pickup was mated with one or two Fender-style single coils, I might consider a 250K volume pot.
