Old April 28th, 2009, 11:42 AM   #1 (permalink)
SpinWheelz's Avatar
Anyone tried the GFS Neovin Tele pickups?
http://store.guitarfetish.com/nenofrpifort.html
Anyone tried these? I did a search and the results came back a bit thin.
Cheers.
SpinWheelz is offline   Reply With Quote
Old April 28th, 2009, 08:45 PM   #2 (permalink)
blingdogg's Avatar
They only became available for sale this week. they're brand new.
blingdogg is offline   Reply With Quote
Old April 28th, 2009, 11:58 PM   #3 (permalink)
SpinWheelz's Avatar
Is that right? I had no idea - I just stumbled upon the offering while I was shopping around for a bridge pickup.
Old April 29th, 2009, 12:14 AM   #4 (permalink)
what the? I didn't know these were out yet!!! i'ma get on that quick time!!! :D
joebonilla is offline   Reply With Quote
Old April 29th, 2009, 09:29 AM   #5 (permalink)
SpinWheelz's Avatar
I wouldn't mind making an order to try 'em out. But before I do, thought I'd get some input first.
I've got 500K pots in my current Tele (I suspect it's because I have a humbucker at the neck). I'm also using a 0.033 cap. Now, the GFS suggests 250K pots for their Pure Vintage bridge pickup, but a 500K pot for their Hard Vintage bridge pickup.
Now, granted, I know these are very new "untested" pickups. But in terms of electronic principles, what effect can I expect if I mated a pickup that's been "specced" for 250K pots, to a 500K pot?
Old April 29th, 2009, 09:31 AM   #6 (permalink)
Tele Fan's Avatar
It will be brighter than it usually would be.
Life is better when you just make it up as you go along.
Tele Fan is offline   Reply With Quote
Old April 29th, 2009, 09:40 AM   #7 (permalink)
GhostofJohnToad's Avatar
These look interesting. I've been wondering when they would offer these.
GhostofJohnToad is offline   Reply With Quote
Old April 29th, 2009, 11:01 AM   #8 (permalink)
aunchaki's Avatar
Hello Birthday wish list...
There's a good in-depth review of the Strat NeoVins by Rob DiStefano. It's not the same thing, of course, but some of his thoughts probably apply to these as well.
Two Teles + One Strat + Three Acoustics (6, 12 & solidbody 6) +
Two Mandolins (4 & 8 strings) + One Bass (5 strings) = 59 strings total
Old April 29th, 2009, 12:55 PM   #9 (permalink)
just ordered a set of the Hard Power Vintage
"Cowboys to Girls"
Doug 54 is offline   Reply With Quote
Old April 29th, 2009, 05:17 PM   #10 (permalink)
SpinWheelz's Avatar
GFS seem to be making a really big deal out of this "get it as close to the strings as humanly possible" setup. What's this about? Is this about compensating for a design intricacy/flaw? Is this a feature of all/most noiseless single-coil pickups? Is it possible that one might need to get the pickups so high that it's the guitar becomes "unplayable" (silly question probably, but I thought, what the hell)?
Old April 29th, 2009, 05:35 PM   #11 (permalink)
SatelliteOrders's Avatar
The closer to the strings, the closer the strings to the magnet, the more the pull of the magnet saps sustain. Yes, it is possible, even not at "touching the strings" height.
SatelliteOrders is offline   Reply With Quote
Old April 30th, 2009, 12:20 AM   #12 (permalink)
Ringo's Avatar
re close to strings
depends on the type magnets used, vintage single coil pu's w alnico magnets will cause problems if the pickups are adjusted too close to the strings, but some other designs don't do that , noteably the Bill Lawrence noiseless, Lace Sensors and others.
Old April 30th, 2009, 12:39 AM   #13 (permalink)
aunchaki's Avatar
Originally Posted by Ringo View Post
...some other designs don't do that , noteably the Bill Lawrence noiseless, Lace Sensors and others.
Exactly. Lace Sensors need to be VERY close to the strings. They don't use six magnets, but lots of smaller, weaker magnets (or something like that).
I'm not worried and am starting to work my brain into ordering a bridge pickup for my new Esquire project (hmmm... Pure Vintage or Hard Vintage??).
Old April 30th, 2009, 03:59 PM   #14 (permalink)
Well, just ordered a vintage set today. So I'll let you all know when I get them and get 'em in.
Old April 30th, 2009, 04:40 PM   #15 (permalink)
blingdogg's Avatar
I can't wait to hear from you guys who ordered a set. Yes, keep us posted!!
Old May 6th, 2009, 11:47 PM   #16 (permalink)
SpinWheelz's Avatar
My pickup arrived today, and I had everything lined up to install the pickup tonight. Alas, it was not to be. The plate beneath the pickup isn't aligned to the bobbin, which means that the mounting screws will not fit into the holes. I'm really bummed, but I've written GFS and hopefully I'll hear back about an exchange.
Old May 7th, 2009, 12:06 AM   #17 (permalink)
Uma Floresta's Avatar
I had the same problem with my GFS Tele lipstick bridge pickup. I ended up redrilling one of the holes so it would mount correctly.
Uma Floresta is offline   Reply With Quote
Old May 7th, 2009, 07:37 AM   #18 (permalink)
Huh, I received mine but didn't look close enough. Mine are for a build not quite ready yet. I'll have to see if that is true with my set as well.
Old May 11th, 2009, 11:29 AM   #19 (permalink)
SpinWheelz's Avatar
GFS customer service? Second to none. They sent out another pickup after I contacted them about the misalignment, and I got it over the weekend.
This may be a production problem here because the second pickup was misaligned as well. Upon closer inspection, here's the deal - the base plate is glued to and aligns perfectly with the bobbin; problem is, the holes in the bobbin and the holes in the plate don't line up. So to make the second pickup work, I took the mounting bolt and screwed it in from the bottom up and it "forced" a wider - and aligned - hole in the bobbin. Thankfully, it didn't cause the plate to detach from the bobbin.
I'd be curious to know if I just got super unlucky and ended up with two unfortunate pickups, or if others are having the same issue with this first-run.
My other gripe is the springs and the mounting bolts themselves. Compared to my old pickup, these mounting bolts are narrow, which meant there's a very small amount of play in the bridge because the bolts don't fit snugly in the holes in the bridge. To make matters, the springs are as soft as tofu. Which mean even more play when mounted to the bridge. However, when I replaced the springs with my old, harder springs, the pickups became more securely fastened to the bridge, despite the narrower mounting bolts.
So, it's a 5-conductor pickup. Five! Last time I had a five-lead pickup was pair of Bill Lawrence L-500 humbucker pickups!. I didn't even know that 5 leads was possible in the single-coil pickup. And the poles are flush to the bobbin, they don't stick up.
Soundwise? I seem to get the twang only when I pick really hard. To be more precise, I feel like I have to pick a bit harder than my old pickup to get that twang. I do have the pickups set fairly close to the strings, per the instruction, but when I pick harder, I do get some nice twang for it. When I pick more gently, I'm getting a slightly squawky tone, which I quite like. Noiseless? Absolutely. Now, this is only about a half-hour's worth of playing, so I feel like I've got lots more to test out and optimize.
Old May 11th, 2009, 11:34 AM   #20 (permalink)
Thanks for the review. I look forward to reading your thoughts after you've had more time with it.
Which flavor did you get?
Old May 11th, 2009, 01:04 PM   #21 (permalink)
SpinWheelz's Avatar
The Hard Vintage pickup. Seemed to be the right match for the humbucker in the neck.
Old May 18th, 2009, 03:55 PM   #22 (permalink)
blingdogg's Avatar
Anyone else tried them yet? I'd like to hear more opinions on how they sound.
How do you like the tone of the neovin after a few more days with it?
Old May 18th, 2009, 04:05 PM   #23 (permalink)
They're bladed dual coil humbuckers, and the poles are part of the ground array/don't sense the string.
Derek Kiernan is offline   Reply With Quote
Old October 30th, 2009, 06:07 PM   #24 (permalink)
DavidP's Avatar
Any more feedback on these??
Especially the vintage strength models? I'm thinking of trying one in the bridge position of my Reverend Buckshot--its fully exposed in the route so noiseless may be worth trying out. It also has to balance the (excellent) Revtron mini HB in the neck.
barely in tune and teetering on the brink of oblivion...
DavidP is offline   Reply With Quote
Old October 30th, 2009, 11:29 PM   #25 (permalink)
I put the power rock overwound bridge neovin on one of my tele copies. The neck pickup is a GFS p90. This particular neovin has a great sound, but not really a tele sound. I call it a Les Paulicaster. If you want that sound get it. I prefer the sound of GFS fatbody pickups, which is a traditional tele sound but with more guts. I'm debating changing the neovin for an overwound fatbody. My other tele copy has GFS fatbody pups on the neck and bridge and sounds great.
Dadawads
dadawads is offline   Reply With Quote
Old October 31st, 2009, 01:10 AM   #26 (permalink)
boris bubbanov's Avatar
The fact that there's no Rob DiStefano review of these pickups is, IMO, a very ominous sign.
I wish you guys the best of luck.
When i listen
Old October 31st, 2009, 02:16 AM   #27 (permalink)
Just to reply to Boris,
On my tele copy with GFS fatbody pups, I had replaced Fender Japanese tele pups that came from a Fender Antigua Telecaster. The GFS were bigger and sweeter in sound. I don't care whether Rob ever reviews them. That logic does not stand up for me. The fatbody pups are truly excellent.
Dadawads
Old October 31st, 2009, 07:13 AM   #28 (permalink)
Fajah's Avatar
I can't help you with the bridge pickup, but I just received 3 Neovin (NeoTN7) neck pickups which will be installed in 3 STL-50's. The physical installation is complete so they just have to be soldered, hopefully today. Once done, I'll post my thoughts.
Mr. Lawrie Mann
Toronto, Canada
Guitar Gear
Bass Gear
Band
Fajah is offline   Reply With Quote
Old November 1st, 2009, 04:10 PM   #29 (permalink)
blingdogg's Avatar
I never knew Rob DiStefano is the ultimate judge of what is good or not for everybody...
Old November 1st, 2009, 06:41 PM   #30 (permalink)
I think the comment was made because Rob did the Neovin review for the Strat set, and it seems like he hasn't investigated the Tele offerings.
Old November 1st, 2009, 07:11 PM   #31 (permalink)
blingdogg's Avatar
Oh, ok, I didn't know about that.
Old November 4th, 2009, 10:17 AM   #32 (permalink)
Fajah's Avatar
GFS Neovin Neck Pickup (NeoTN7) Thoughts
So I just finished the installation of GFS' Neovin neck pickups in three STL 50's. The physical installation was straightforward. On one of the three guitars, the bottom edge of the hole in the pickguard needed to be filed down a bit so the pickup would sit straight up and not on an angle. The pickup on my guitar is on a slight angle but barely noticeable and the third guitar was fine.
Wiring it up was also straightforward although if you follow the included diagram, it will be out of phase with the STL's stock bridge pickup. This was consistent with all three guitars. The "out of phase" sound is very interesting when in the middle position, but a tiny bit of hum comes through at higher volumes. The hum does get picked up when you record. I found this out when I did a recording with the pickups out of phase before correcting it.
I find that the Neovin is cleaner and brighter than the stock neck pickup while still maintaining some warmth and bottom end. Most important for me.....it's dead quiet. When in the middle position, it cuts down the single coil hum coming from the bridge dramatically.
Here a link to the sound sample I recorded for your listening pleasure:
http://www.box.net/shared/nyk74y8q87
First sample is the stock STL neck pickup, followed my the Neovin neck pickup, and then both the Neovin neck and stock bridge pickups together. My guitar was plugged into a Cube 60 set on JC Clean with a bit of reverb. Tone controls on my amp were set flat with the volume and tone controls on my guitar wide open. My strings are Ernie Ball Slinky 10's and I used a medium pick. Lastly, I haven't changed my strings since the summer.
One last thing on the setup. The neck pickup's height is set very close to the strings (as per GFS' instructions). The bridge pickup height has to be adjusted for tonal taste and balance for when in the middle position, it can overpower the neck and lose some warmth. It's personal taste of course.
All in all I'm really happy with it. Like all GFS pickups I've used so far, it's great value.
Mr. Lawrie Mann
Toronto, Canada
Guitar Gear
Bass Gear
Band
Old November 4th, 2009, 11:09 AM   #33 (permalink)
Sounds very nice
Fender MIM pickups VS GFS TC Alnico Tele Pickups gstevenett Just Pickups 1 March 11th, 2009 03:06 PM
GFS Neovin - very weak neck pickup andy__woods Just Pickups 9 January 24th, 2009 08:32 PM
GFS Neovin "Fat Vintage" Noisefree Fat Bridge Pickup set ole6string Just Pickups 0 October 2nd, 2008 01:07 PM
GFS NeoVin ... ? Rob DiStefano Just Pickups 15 September 4th, 2008 06:10 PM
Original Vintage TeleŽ Pickups or Texas TeleŽ Pickups? RichardM Just Pickups 6 June 8th, 2007 12:56 AM
