Old March 9th, 2009, 02:00 PM   #1 (permalink)
Okay, I'm really frustrated now...
Okay, I bought a GFS neck p-up from a member here, and a 7k GFS Fatbody Bridge p-up from a different member here. Good prices and fast delivery on both. Neither of them came with springs/screws. Changing out the p-ups on my Affinity Tele.
Doesn't appear that the neck p-up will be a problem However, when I tried to mount the bridge p-up, I found the original Squier mounting screws are larger than the holes in the GFS p-up. Guess I didn't think there would be a difference in mounting hole/screw size.
So, not having a drill/tap set; a trip to the hardware store in order? Or can anyone give me any suggestions?
Also, while putting things away, I noticed the brass plate on the bottom of the bridge p-up is loose and wants to seperate/turn from the bottom of the p-up; is this okay, or is the baseplate supposed to be glued/attached to the bottom of the p-up? This p-up doesn't look like it's ever been used/installed, so I'm wondering why the base plate would be loose?
This is my first attempt at doing this myself, so far, I'm wishing I had taken it to my tech! Just need a little guidance, please...
91xlntS-3 is offline   Reply With Quote
Old March 9th, 2009, 02:52 PM   #2 (permalink)
I often have to go to the hardware store when I change pickups. When I put Toneriders into my tele, the screws that came with the pickups were too long, or the guitar route wasn't deep enough. The shorter screws I found at the local hardware store worked fine, but they were slot head instead of phillips. No big deal.
john
Having said all that, I might be wrong.
2ndstringer is offline   Reply With Quote
Old March 9th, 2009, 03:08 PM   #3 (permalink)
Goluphi's Avatar
This is something I've run into with a few GFS pickups: the glue that they use to hold them together is...not the greatest. I found that the bridge pickup became microphonic when the glue failed and the baseplate separated from the rest of the pickup.
I noticed that GFS used some sort of glue to hold the pickups together in the first place, so I just dabbed on a bit of my own and closed the pickups back up. I don't know if this is the "right" thing to do, but the pickups work great (and seem to be holding up just fine).
Goluphi is offline   Reply With Quote
Old March 12th, 2009, 05:45 AM   #4 (permalink)
Quick Update:
Reglued the base plate on the Bridge p-up.
Had a set of mounting screws from my Am. Std. Tele that were just what I needed, and now the bridge p-up is mounted and the bridge assembly is back into the guitar.
Got everything wired up and plugged into an amp. The Bridge p-up is the 7k Fatbody, man this is one HOT p-up if it is only 7k! The neck p-up seems to be a problem, it is the I31 model, and the chrome cover can be removed. I had the neck p-up adjusted as close to the strings as I could, with the bridge p-up adjusted down about half way from the strings and they just do not balance out! The neck p-up sounds week and kind of dull sounding. Not as much as the original Squier p-up, but at least I had a good balance with both the original Squier p-ups.
So, since I have to take the neck p-up out to take off the chrome cover, I'm wondering if I shouldn't replace it with something else? I have the neck p-up from my '04 MIA Tele, but am wondering if the 7k bridge p-up may be too hot for my tastes? Or do I just need a hotter neck p-up? I really like the tone of the Fatbody, just need something to balance better with it.
I bought these p-ups, as they were a real deal ($42 for both). And since I am laid off, thought it would give me something to do (besides dishes and laundry) without my wife being too upset that I spent the money. Guess I'll try using the MIA p-up and see what happens. If this doesn't work, I may have to save my pennies for a Fatbody neck p-up!
Suggestions always welcome...
