Power to the pickup - measurement - Telecaster Guitar Forum
Old March 1st, 2009, 12:08 PM   #1 (permalink)
robbysturgis's Avatar
Can you measure a pickup as to power, such as measuring Ohms.
I've got an Ohm meter, should it register a reading?
In early '57, I bought a Fender Telecaster. ~ Johnny Rivers
http://members.cox.net/robbysturgis/...plus1small.jpg
robbysturgis is offline   Reply With Quote
Old March 1st, 2009, 12:52 PM   #2 (permalink)
RodeoTex's Avatar
I'm not sure how it would read but I suspect that the OUTPUT power of a pickup would be measured in millivolts. It would probably best be done using an oscilliscope with a memory function.
I'm sure someone will jump in here and tell how it could be done properly in the real world.
Old March 1st, 2009, 01:12 PM   #3 (permalink)
charlie chitlin's Avatar
Just put an ohm meter on the 2 leads.
Should read somewhere from about 7-14 ohms, depending on the pickup.
If it's in the guitar, you can plug in a short cable, turn the volume and tone up and touch the 2 parts of the plug. It's not exact, but it's close.
charlie chitlin is offline   Reply With Quote
Sponsored Links   #
Old March 1st, 2009, 03:26 PM   #4 (permalink)
so in other words, If I'm getting no ohms from one lead to another, the pickup is dead.
Old March 1st, 2009, 03:48 PM   #5 (permalink)
RodeoTex's Avatar
I guess I'm not understanding what you are trying to measure. I was a bit confused because there is no power going TO the pickup.
Are you just trying to see if the pickup is good? Then yes, just putting an ohm meter on the leads will tell you that.
Old March 1st, 2009, 10:41 PM   #6 (permalink)
C R A P
» Random Photo for Guests
My Girls
» Recent ThreadsGuests
Fender Logan Custom Guitars
