Pick-up Help...Don Mare, you there?
I have a G&L ASAT Classic Tribute that I absolutely love. (I am obviously an amatuer
Waking up is a prerequisite for every good day! |
#2 (permalink) | |
More wax potting will definately cut squeal, but the question is...will it suck tone??? I don't know the answer to that, but will be interested in hearing opinions. I know that some guys equate good tone with a more microphonic pickup (less wax).
#3 (permalink) | |
"thanks , my pickup is waxed by my guitar tec Dominick Ramos, so if you have someone who knows how to put just the right amount of wax on without killin the highs of the pickup you can stand in front of an amp with a tele and sustain without the bird chirps!! take care , Jim W"
ideally, the base plate should be perfectly flat and 100% stable, to keep it from vibrating like an oboe reed. the funky ol' Fender plates sound best to me, but they're often irregular ... i put 'em on a belt sander to flatten the underside, and also add smaller screws to the top of the plate to keep it stable.
you can also try stuffing your pickup cavity with foam, that's worked for some people. it's your axe, but if it was me, i'd try to avoid altering a good-sounding pickup.
Truth is stranger than fact ... It pays to appease all the gods — Gnossos Pappadopoulis Original tunes from the Woodshed |
#7 (permalink) | |
I've run/spooled thread over the string on Tele bridge PUPs, like 1/8" worth and had decent success with squeal.
A Twin always will cut it... but I don't recommend it for everybody. It's like a big dog, you have to take responsibility for it. Not to mention... be prepared to lift it. BTW, how $good$ a guitar is, is no indicator of how badly it can be played! |
you wouldn't be modding the pickup — just the bridge plate.
Some silicone between baseplate and pickups helps a lot, but proper potting will kill squeal without hurting tone. 5 minutes in the pot with very thin mix (more beeswax, less parafin) will do the trick.
But sometimes the bridge on your Tele is the culprit. Some are made very thin and aren't screwed down on the end facing the neck and they can vibrate pretty bad. |
#11 (permalink) | |
I found some sticky, spreadable beeswax that's made for crafts. I spread it on the bottom of the pickup, put the baseplate on it and heated it with a soldering iron to re-flow it. It worked great!
I don't like the idea of using silicone. It's pretty acidic.
Don |
