Old April 30th, 2003, 10:18 AM   #1 (permalink)
Brewbaker's Avatar
Lowering poles on Strat PUs--?
Has anyone tried pushing down the G and D string poles on staggerd Strat PUs? I seem to remeber hearing about heating the PU and getting the wax soft and then puhing on the pole--did I dream this or has someone actually done it? Those strings are driving me nuts.
Brewbaker is offline   Reply With Quote
Old April 30th, 2003, 02:38 PM   #2 (permalink)
Jack L.'s Avatar
Lowering poles on pickups...
I wouldn't recommend trying to lower the pole pieces. You might end up with a broken winding. Of course, the newer pickups might be wound differently than older pickups. I've heard you might be able to apply a small amount of heat via a solder iron(low wattage), and then carefully push down on the pole piece.
I like the staggered pole piece pickups, but some pickups I've seen have the pole pieces too high, which might be the case with your pickups.
Take care,
Jack L.
Jack L. is offline   Reply With Quote
