Old November 28th, 2008, 02:49 PM   #1 (permalink)
chicknpikr's Avatar
2 volumes no tone/
never thought about this but found it in a forum.2 volume controls would blend between pickups... then whats something cool you could do with the switch?
anyone done this or have a schematic for it?
If the club owner tells you to turn down you must be doing something right!
chicknpikr is offline   Reply With Quote
Old November 28th, 2008, 05:44 PM   #2 (permalink)
nasonm's Avatar
That's basically what the John 5 tele is. It's not bad but sometimes I feel it's limiting to dial in certain tones.
"i have learned to just grit my teeth, change the subject, consider their deep total ignorance, fondle the thumb picks in my pocket and go on my way" - bender-freak
It's been lonely in the saddle since my horse died
nasonm is offline   Reply With Quote
Old November 28th, 2008, 06:12 PM   #3 (permalink)
octatonic's Avatar
You can always go for two volumes and one tone.
A small mod to a control plate- takes about 1/2 an hour to do.
Old November 28th, 2008, 10:18 PM   #4 (permalink)
i've got two volumes and no tone controls in my tele deluxe. i like it mainly for the simplicity, but there's also the benefit of a 'purer' and less filtered sound that appeals to me even if it's barely noticeable.
i've got the hot lead of my pickups going to the center lug of their respective volume pots, then a wire runs from lug 3 of each pot to the switch and then from there to the output. other than the ground connections, that's all there is to it. i think by connecting the pickups to the center lug (2) rather than the outer lug (3) you eliminate the problem of both pickups shutting off in middle position when the volume is turned all the way down on one control.
jivetrain is offline   Reply With Quote
Old November 30th, 2008, 05:29 PM   #5 (permalink)
patrickhowell's Avatar
I think it would make more sense to use a single volume and a blend knob with a center detent so you don't have to mess with both volume knobs to get the right mix. You could use the switch for series/parallel, in/out of phase, or fixed tone caps.
patrickhowell is offline   Reply With Quote
