Old August 6th, 2008, 01:15 AM   #1 (permalink)
Gibson's Avatar
Yet another four-way question -- a quickie!
I'm going to put a four-way switch in my partscaster, following the Seymour Duncan schematic.
I'm also putting a P-90 in the neck, which has three conductors including a bare ground. Should it be wired in the same way as a regular Tele neck pup for four-way switching?
Thanks!
Gibson is online now   Reply With Quote
Old August 9th, 2008, 08:07 AM   #2 (permalink)
PeteMac's Avatar
Hi Gibson
I'm pretty sure your 3 wire P90 will wire up just as a normal 4 way switch set up.
The S.Duncan wiring diagram is a little different to the Fender one, I think, But essentially the same.
Your P90 will have a positive, a negative and a ground wire, which is what's needed for the 4 way to work.
Good luck.
"Find what you like . . . and let it kill ya . . ."
(Kinky Friedman)
www.myspace.com/theboneyarsedboys
PeteMac is offline   Reply With Quote
Old August 9th, 2008, 02:03 PM   #3 (permalink)
Gibson's Avatar
Good to know, thank you.
