How to wire a Twisted Neck Pickup?
Hi,
how do I wire a Baja Twisted Neck Pickup in a standard tele pu wiring? I know the green wire is the cover wich goes to ground, but which of the other 2 (black&yellow) is the hot one for a non-outofphase wiring? I'll suggest the yellow one and the black one goes to ground, but am I right? thx Patrick |
| Sponsored Links |
#2 (permalink) | |
I don't think it's wound differently. The internal structure is different, with the poles and the cover and such, but I think the winding is "standard", I don't know.
Regarding the wiring, on my Baja, the green pickup connects to ground, and the yellow/black ones connect toi the S1 switch, but I really don't understand what's going on there... http://www.fender.com/support/diagra...141502APg2.pdf |
#4 (permalink) | |
@DWBH Yes, I also looked at the schematic/layout and didn't get it. Thats why i'm a little bit confused about the wiring on a regular 3way tele switch. :) |
I listened to the Custom Shop YouTube of the neck pup. It sounds exactly like my copper tape wrapped / shielded Strat PUP I have in the neck of one of my Teles. Chimey and throaty like a nice Strat.
We are cross threading on this: http://www.tdpri.com/forum/telecaste...e-pick-up.html |
Your guess is correct.
Yellow is hot - wire that to your non-S1 switch. The other two (black and green) are grounds and can be soldered to the back of either pot. You may also want to try a 4-way switch sometime. Your twisted tele pickup is already set up for that with the extra ground wire for the cover. |
#9 (permalink) | |
It's not exactly a reverse wound pu, it is just set up with an extra wire for the covers ground. So you are ready to reverse the polarity and/or switch between serial or parallel mode with the bridge pickup in the middle position and the cover always goes to ground. Normally the cover would be wired "inside the pu" to the ground wire from the pus winding.
