Old June 23rd, 2008, 01:03 PM   #1 (permalink)
rockycreeker's Avatar
Hum From EMGs?
I bought a set of EMG Tele pups on ebay a while back. They looked perfect cosmetically. My guitar repairman who does all my work installed them for me. They sound fine, except the bridge pup does have some hum when you get close to the amp - this also can be heard when combined with the neck pup. The neck pup by itself is dead quiet.
Played live in normal situations, I don't notice it, cause I don't get that close to the amp, but I'd like to nail the problem.
Could it be an installation problem or a faulty pup? Any ideas?
Playing music is a permanent sickness
rockycreeker is offline   Reply With Quote
Old June 23rd, 2008, 01:50 PM   #2 (permalink)
maestrovert's Avatar
i'd make sure the ground is disconnected 1st thing, EMGs do not require string grounding...
Sing the Song Bro'
Play on Drummer
www.godonthe.net
Old June 23rd, 2008, 02:11 PM   #3 (permalink)
Didn't think about that.. so if the bridge pup were to be grounded in the conventional way, it could cause hum? I'll check it out. Thanks Mastrovert!!
Old June 23rd, 2008, 09:12 PM   #4 (permalink)
bradpdx's Avatar
Grounding EMGs conventionally will NOT add hum. In some cases it may help, but not here.
No, the bridge pickup is simply not 100% hum cancelling - the two coils are slightly different. I too have observed this with EMG-T sets and it is true for most humbuckers.
Don't sweat it. When you get your guitar close to the amp, you are creating an extreme situation unlikely to occur when playing. In reality the EMGs are very, very quiet. Just not dead quiet.
String bender ordinare!
Old June 24th, 2008, 07:33 AM   #5 (permalink)
cdhopkin's Avatar
I get hum from my EMGs (all my Strats are loaded with EMGs) when I'm playing with a bit of gain and in front of my pc...They are very quiet but not totally foolproof.
Just make sure the strings aren't grounded. EMGs are double grounded internally and they recommend disconnecting the string ground as it could cause a ground loop.
cdhopkin is offline   Reply With Quote
Old June 24th, 2008, 10:53 AM   #6 (permalink)
kludge's Avatar
Check your cables, too... I've found that switching cables can kill hum that seems to be coming from the pickups.
Oz: Well, other bands know more than three chords. Your professional bands can play up to six, sometimes seven completely different chords.
Devon: That's just, like, fruity jazz bands.
-from Buffy the Vampire Slayer
kludge is offline   Reply With Quote
Old June 24th, 2008, 03:58 PM   #7 (permalink)
Thanks for input guys. I spoke with my guitar repairman and he didn't remember if he grounded the strings or not. Like Bradpdx said, it's not a major problem, but I will get the string grounding thing checked out. Thanks guys.
Old June 24th, 2008, 04:27 PM   #8 (permalink)
cdhopkin's Avatar
Another thing you could check is if it's related to one particular amp/pedal combination or location where you are playing...Lots of possibilities.
Old June 24th, 2008, 05:05 PM   #9 (permalink)
Well, my main guitar is a Fender Strat that I've EMG SAs in forever, and I don't get any hum out of them, so I don't think it's any particular effect that I may be using. Of course the more gain stuff I have going on, such as compression, overdrive, etc, the more the hum is noticeable, but I just don't think it's that.
With the Tele, as soon as I switch to the neck pup alone, bam - the hum is totally gone. I can hear the hum with just the guitar plugged straight into the amp. I have three Fender amps, a 66 Twin, a 66 Vibrolux and a 76 Deluxe and the hum is noticeable with all of them. But of course I have to be really close to the speakers to hear it.
Old June 24th, 2008, 05:35 PM   #10 (permalink)
very true...it could be a number of things
supersoad1 is offline   Reply With Quote
Old June 24th, 2008, 05:39 PM   #11 (permalink)
nicktele5150's Avatar
well i learned somethin new today i thought emgs were completly noiseless lol
nicktele5150 is offline   Reply With Quote
Old June 24th, 2008, 05:50 PM   #12 (permalink)
cdhopkin's Avatar
It might be worth checking the wiring to see if the briad for the bridge pup is soldered to the back of the volume pot correctly. If this was a Strat I'd suggest swapping out the p/up (assuming yours use the quikconnect cables) to see if it's the p/up or the wiring.
Another thought is that something is being grounded that shouldn't be grounded when the switch is selecting the bridge p/up on it's own.
Old June 24th, 2008, 07:10 PM   #13 (permalink)
mine are, but then i don't use od/dist fx or "hi gain" amplification....
Sing the Song Bro'
Play on Drummer
www.godonthe.net
Old June 24th, 2008, 08:14 PM   #14 (permalink)
ive always heard they were i just dont like active pickups
nothin beats a good tele
Old June 24th, 2008, 08:27 PM   #15 (permalink)
The same deal - some folks like EMGs, some don't. They work for me - to each his own. Putting EMGs in my Tele allowed me to interchange it with my Strat on gigs without having to reset my rig, but there is still a difference between guitars, i.e my Tele still sounds like a Tele. I've always said they are real world pickups.
Old June 25th, 2008, 01:09 AM   #16 (permalink)
cdhopkin's Avatar
My guitar teacher had a Strat with a 70 body / 64 neck (neck) fitted with EMG SAs. He was able to get all the tones under the sun from it and never sounded "sterile" even through a 15w tranny practice amp.
I've got 1 Strat with an 85/SA/SA combination and another one with 3 SAs plus the SPC mid boost. I'm rejigging my Strats at the moment and am going for two with all SAs - I'm going to mount the SPC into a stompbox.
vB code is On
Forums Directory
