Old May 22nd, 2008, 03:54 AM   #1 (permalink)
markothefish's Avatar
Springs or Tubing for p/u height adjustment
What do you guys like to use when you swap out pick ups , Springs or Compressible Tubing like Fender uses for height adjustment . And what would be the pros and cons of each . I like the way the tubing holds things in place while I'm putting things together , but am I missing something ??
Who are you going to believe, me or your own eyes?
Groucho Marx
markothefish is offline   Reply With Quote
Old May 22nd, 2008, 10:31 AM   #2 (permalink)
spankdplank's Avatar
I think springs are more likely to cause feed back than compression tubing, especially in a microphonic or unpotted pickup, but this can be a good thing, depending on the pickup. After 15 years or so, the compression tubing will rot and crumble and will need replacement. Springs should last as long as the guitar. YMMV.
spankdplank is offline   Reply With Quote
Old May 22nd, 2008, 10:32 AM   #3 (permalink)
Stan Martin's Avatar
I prefer springs
I think the pros of the tubing is your pickup will be less prone to vibration/feedback, due to the damping qualities of the tubing.
I guess the cons would be that the tubing breaks down after a while and is less flexible(gets tacky).
The pro for springs-Leo used it,supposed pickup vibration (in a good way ).
ymmv
Stan Martin is offline   Reply With Quote
Old May 22nd, 2008, 10:43 AM   #4 (permalink)
maestrovert's Avatar
Springs are generally capable of more downforce than tubing, which can be a factor with P-ups of a more microphonic nature....if you find that to be the case, try springs of lesser strength like those used in retractable ink pens...
as noted, tubing will eventually dry and fail
Springs for me btw
Sing the Song Bro'
Play on Drummer
www.godonthe.net
Old May 22nd, 2008, 11:48 AM   #5 (permalink)
Wardpike's Avatar
Tubing all the way, replace every 5 to 10 years.
Old May 22nd, 2008, 12:05 PM   #6 (permalink)
surfoverb's Avatar
I thought I saw a 1950 Broadcaster pickup with tubing recently here somewhere but I could be wrong...I've tried both and didn't find a difference in tone but found the springs to be less stable or the pickup moves around more it seems...Try them both YMMV.
Old May 23rd, 2008, 09:58 AM   #7 (permalink)
does anybody know were to get tubing?
bukowski is offline   Reply With Quote
Old May 23rd, 2008, 10:05 AM   #8 (permalink)
magicguitar's Avatar
Stewart McDonald: http://www.stewmac.com/shop/Hardware...ng_Tubing.html
magicguitar is offline   Reply With Quote
Old May 23rd, 2008, 03:31 PM   #9 (permalink)
DADGAD's Avatar
The tubing is surgical tubing. Hospitals & doctors toss used stuff all the time. It might be available at drug stores, too.
"I need to learn some new scales and stop obsessing about this stuff."
http://www.myspace.com/slickshoes
DADGAD is offline   Reply With Quote
Old May 26th, 2008, 09:48 PM   #10 (permalink)
Del Pickup's Avatar
I find the springs are more difficult to work with when installing the pups but once in place then no real difference between them as far as I can tell.
Del Pickup is offline   Reply With Quote
Old May 26th, 2008, 10:00 PM   #11 (permalink)
robt57's Avatar
Ron Kirn made a comment in another thread that surgical tubing attacks Nitro, and he uses silicon for that reason, FWIW. I'm assuming he means latex surgical tubing attacking Nitro.
Also FWIW, not all surgical tubing is latex, just most. They have to use silicone for drains. My wife is an OR tech so I asked her bout that.
Apparently hobby shops have the silicon if anyone is looking for source.
vB code is On
Forums Directory
