Old May 21st, 2008, 04:36 PM   #1 (permalink)
Anthonyray200's Avatar
just volume
i would like to know who to wire a single p90 pickup to just volume and only volume if you could make up a diagram it would be easy thanks
Hi
Anthonyray200 is offline   Reply With Quote
Old May 21st, 2008, 06:27 PM   #2 (permalink)
MulliganChebichev's Avatar
Here's this diagram
If your P-90 is braided, solder the braided sleeve on the pot, and the hot on the lug.
The cap and resistor is a treble bleed kit, it isn't needed.
MulliganChebichev is offline   Reply With Quote
Old May 21st, 2008, 09:42 PM   #3 (permalink)
in the diagram what is green
Hi
Old May 22nd, 2008, 12:01 PM   #4 (permalink)
Wardpike's Avatar
One Pup or Two+?
Is this a single pickup guitar or are you referring to wiring in a P90 into an existing guitar that also has another pup?
If such is the case, then your work begins and ends with the pickup selector. The existing tone pot will be wired directly to the lug connected to the pup that you want the tone control to work on, and the P90 will be unafected by the tone control.
I hope I've been helpful,
Ward
vB code is On
Forums Directory
