Old May 20th, 2008, 04:28 PM   #1 (permalink)
How to lower Humbucker output
I have a Tele with a neck humbucker - its a bit too hot for what I want but has a nice tone. I can get the clean tone I want with the vol pot turned almost all the way down & the amp turned up. Doing it this way I lose any real control over volume using the guitar controls. What I'd like to do is attenuate the humbucker output a bit to avoid overdriving the amp & thereby get a bit more control over volume from the guitar. Is there any way to do this - I thought maybe bleeding some of the signal to ground via a resistor at the output jack might do it ... or is this way too simplistic ? any ideas anyone ?
Holdgate is offline   Reply With Quote
Old May 20th, 2008, 05:22 PM   #2 (permalink)
Daddydex's Avatar
Try lowering the pickup. That should do it.
Dan
Teles are like Mr. Potato head
Daddydex is offline   Reply With Quote
Old May 20th, 2008, 05:23 PM   #3 (permalink)
aznrambo481's Avatar
lowering the pickup SHOULD do the trick.
"Never age. Never die. Live forever in that one last white-hot moment, when the crowd screamed. When every note was a heartbeat. Burn across the sky."-Terry Pratchett, Soul Music.
aznrambo481 is offline   Reply With Quote
Old May 20th, 2008, 05:48 PM   #4 (permalink)
maestrovert's Avatar
a separate vol pot -concentric if space is a factor- for the neck 'bucker would do the trick too
Sing the Song Bro'
Play on Drummer
www.godonthe.net
Old May 20th, 2008, 07:07 PM   #5 (permalink)
esteban's Avatar
It seems like he'd have to lower it a bunch, from the way he described the output. Wouldn't clarity be sacrificed?
When I die, they'll say, he couldn't play sh*t, but he sure made it sound good. - Hound Dog Taylor
esteban is offline   Reply With Quote
Old May 20th, 2008, 07:17 PM   #6 (permalink)
e-merlin's Avatar
Lowering the pickup will lower output, but you'll probably lose some of the clarity you like. maestrovert hit the nail on the head. A dedicated volume pot can be pre set to the volume you want. Plus, you can turn it up when you need the punch.
'tone is in the underpants'
Old May 22nd, 2008, 10:16 AM   #7 (permalink)
One of my Teles has a Bill Lawrence humbucker........
in the neck position and a standard bridge pickup. I wanted a little more balance between the pickups so I lowered the humbucker till it was almost even with the body and then the volumes of each pickup were pretty close. I then added a single ply Esquire black pickguard right over the pickup and I don't notice any loss of clarity at all. I use it mostly in the middle position but use the neck position by itself on occasion for jazzy or swing type tunes............JH in Va.
Ralph Mooney rules!!
J. Hayes is offline   Reply With Quote
Old May 22nd, 2008, 11:54 AM   #8 (permalink)
Wardpike's Avatar
Perhaps an ingenious way of handling it is tp get a sideways mounted pot like that used on the Fender Jazzmaster as a second setting. Some routing required! Perhaps mounting it about 2" below the front humbuck and leaving the master volume and tone intact.
That might be too extreme for you.
Why not a combination of a hotter output bridge pickup from SD, and dropping the front pup as low as it will go?
I hope I've been helpful,
Ward
Old May 22nd, 2008, 10:39 PM   #9 (permalink)
To put it bluntly the pickup is the wrong one. You don't like the power of the pickup and you have to turn the volume down before you find it usable.
Change the pickup.
What model pickup is it?
Maybe you can list that pickup in the classifieds on TDPRI for trade and see if someone has a pickup more suited to your tastes.
Originally Posted by nasonm
I like my guitars to look like big wooden pieces of candy!
http://www.soundclick.com/bands/page...?bandID=649738
teleman65 is offline   Reply With Quote
Old May 23rd, 2008, 12:47 AM   #10 (permalink)
tjalla's Avatar
Here's a quick fix - remove the polepiece screws from the humbucker. It reduces the effectiveness of that coil, kinda gives a half-single-coil tone. Worked well for a few of the muddier buckers I'd used. Takes all of 5mins, you barely have to loosen your strings, and if you don't like it put em straight back as they were.
my .02
tjalla is offline   Reply With Quote
Old May 23rd, 2008, 12:56 AM   #11 (permalink)
BB
BB's Avatar
my .02
A big plus one. Trev posted this mod a year or two back. Tried it then and it worked very well. Certainly worth 5 minutes of time before buying a new pup!
BB is offline   Reply With Quote
Old May 23rd, 2008, 10:26 AM   #12 (permalink)
Coffeemutt's Avatar
my .02
I read where Seymour Duncan said he used to do this on some homebuckers, but would replace the pole pieces with brass ones (presumably for looks).
Coffeemutt is offline   Reply With Quote
Old May 23rd, 2008, 10:57 AM   #13 (permalink)
Al Nico's Avatar
Before you back the pole pieces all the way out, you may want to try to lower the pickup more and then raise the pole pieces to compensate for the lack of clarity. You'll get more of a single coil tone with the relatively more focused magnetic field around the strings.
Al Nico is offline   Reply With Quote
vB code is On
Forums Directory
