Old May 19th, 2008, 11:44 PM   #1 (permalink)
bradpdx's Avatar
Noisy neck pickup cover
My 52RI has some newer VanZandts, which sound great. Unlike most PUPs, VZs don't come with a neck cover, and so I used an old Allparts chrome cover a friend had in old inventory. Of course I carefully bent the tabs to make it as tight a fit as was reasonable.
The pickup sounds great, but as with many Tele necks in the past it is microphonic when tapped. If I crank up the gain (e.g., compression + overdrive), it will feedback as well from cover vibrations.
The problem isn't severe - I could live with it. The part that bothers me most is the "clink" I get when I hit the pickup with a pick. I don't pick in that position very often, but if I do you can easily hear it.
Long ago I recall addressing this problem with electrical tape on the INSIDE of the cover to dampen it and give it a more snug fit. Any other practical suggestions from the vast experience of the TDPRI?
String bender ordinare!
Old May 20th, 2008, 12:09 AM   #2 (permalink)
BritishBluesBoy's Avatar
Wax potting will fix that...
http://www.guitarnuts.com/technical/...ical/index.php
BBB.
Old May 20th, 2008, 12:38 AM   #3 (permalink)
bradpdx's Avatar
Yeah, pain in the rear but likely the best solution. I wish that VanZandt would just supply a cover!
Old May 20th, 2008, 03:56 AM   #4 (permalink)
RockinCarl's Avatar
Actually, all you probably need to do is take the cover off, and melt a little bit of wax in the cover, and press it back on the pickup. But thats probably what B.B.B. meant anyways.
-Carl
www.Myspace.com/CSB319
RockinCarl is online now   Reply With Quote
Old May 20th, 2008, 10:05 AM   #5 (permalink)
bradpdx's Avatar
That sounds a good deal less involved - I'll give it a try.
What did or does Fender do about this? I cannot recall, I haven't had Fender pickups in years. Are the neck PUPs potted??
I do recall have several old Fender neck PUPs that had this same problem to varying degrees.
vB code is On
Forums Directory
