Old May 9th, 2008, 06:27 AM   #1 (permalink)
Bridge Ground wire mounting point?
Hi Newbie here
Could anyone tell me where the bridge ground wire should be fixed on the bridge side ?
Is it soldered or screwed in?
anything I need to look out for when doing this?
Standard Telecaster wiring used (on a bitcaster)
Many thanks in advance
Reg
reghedley is offline   Reply With Quote
Old May 9th, 2008, 08:14 AM   #2 (permalink)
PhatTele's Avatar
There are many many ways to do this. The main thing is to make sure that the wire makes contact with the bridge plate and stays put. it doesn't necessarily have to be soldered.
In my Teles, I use a multi-filiment wire and I spread the filiments out like a very thin fan. Then, when I mount the bridge, I put the fan under the plate, screw down the plate, and then run the rest of the wire through the pickup cavity into the control cavity where I solder the other end to one of the control pots. It works great.
Old May 9th, 2008, 09:10 AM   #3 (permalink)
Many Thanks for that, much as I thought it might be done but didn't want to chance it.
Again many thanks much appreciated
Old May 9th, 2008, 10:34 AM   #4 (permalink)
4mal's Avatar
generally as the traditional tele bridge pickup is affixed to the bridge using conductive metal screws if the bridge pickup itself is shielded - the bridge already is. In that case you may get a ground loop with the extra wire.
If the bridge pickup isn't shielded then you might consider a copper foil shield in the cavity and let the bridge overlap that. Then ground the shield. You can also solder a wire to small patch of copper foil and tape that to the bottom of the pickup being sure that at least 1 of the screws makes contact.
Somewhere I have of pic of that last as applied to a Precision Bass pickup.
4mal is offline   Reply With Quote
Old May 9th, 2008, 12:12 PM   #5 (permalink)
Thanks for the replies gents
All wired up with your help
Fitted it all together and fired it up this afternoon and works a treat
Only problem is I can't tear my brother away from it
two new converts I believe
Many thanks
Now for the next one I think I'll...........
Old May 10th, 2008, 12:43 AM   #6 (permalink)
boneyguy's Avatar
Many thanks
Try grounding your brother! I'd use extra solder
"Shut up n' play yer guitar"
boneyguy is offline   Reply With Quote
vB code is On
Forums Directory
