| Guitar Owners Clubs Here you'll find owners club threads for many different custom guitars and special models from larger manufacturers, too. |
#87 (permalink) |
56 that is Pine indeed.
![]() Paint by Ron Kirn Here is another one of my Pine Esquires. This one is a monster tone machine and is apple green with a hint of re ranch Fender neck amber on the edges. ![]() My "Green Lantern" I also built a new one a week ago that is simple unfinished pine. Rosewood neck is very bright sounding though. I may need to tame it down with different pickup??
#88 (permalink) |
Arlo, you build those??? Holy sh@t! I love the green apple one. Sweet! Those are beautiful guitars man. I guess I'm still too chicken sh@t to convert one of mine over. I want a rosewood fretboard with a matte white body or a matte black one with a rosewood fretboard. Not sure if the rosewood would look good with matte black or not. I don't want any binding though. Not a big fan of binding, even though I have an American Del. Tele aged cherryburst.
#90 (permalink) |
Seymour Duncan Signature Esquire, modeled after his personal '54 Esquire, and signed by Mr. Duncan hisself. Twang!
"Music is not a competition. The best music is cooperative."- Jerry Garcia, Las Vegas 1993 interview ---------------------- "[Expletive Deleted]"- Richard Nixon |
#92 (permalink) |
Jack that is really cool! I have put some thought into making a replica of the first one too.
I have a question for you? I am putting a SD Lil 59 hum bucker into an Esquire. I want to wire it so that it is essentially typical Esquire wiring but with full dual coil in all positions. What I want is position 1 tone, middle or 2 no tone and the cocked wah in the third position. I have the caps and resistors but I seem to be creating an out of phase problem using the standard E diagram. I twisted the red/white and the black/green together and simply put them where you would normally wire in a single coils. I don't want to split the coils on any position. Have you had any experience trying to wire a hum bucker into an Esquire? |
#93 (permalink) |
Arlo ............. I'd like to help you but I think you're talking above my pay grade. I think this may be a question for Terry Downs.
#94 (permalink) | |
I have a nearly identical setup in one of my Es. SD Little 59, 500k pots. I used the simple wiring diagram on this page and used the .0047 cap for the third position (and a .05 for the other cap). I have had no out-of-phase problems. If it would help you, I can check the wiring tonight. ![]() Update: Red and white wires get soldered together and taped off Green and bare go to ground. Black goes to switch |
#95 (permalink) | |
I'm not sure of which exact colours but you should have it so that 2 of the wires are twisted/soldered together and not connected to anything else, then the 2 leftover wires you connect the same as the diagram for the single coil with one as hot and the other to ground? |
#96 (permalink) |
I think the SD 59 tamed down the brightness I had with this rosewood neck perfectly. Thanks for the help guys Johnny I have the same thing as you except I used a .010 cap and 3.3k resistor in the bassy or third position. This pickup has some overdrive I can see why Billy Gibbons likes it. I gotta try some of Bill Lawrence's Tele humbuckers in an Esquire with his Q filter. I bet that wired with a push pull would give you some serious tone choices. Hugo: I didn't see your post till just now. Yep I done builded me them thar three Esquire's. |
#98 (permalink) | |
http://www.seymourduncan.com/support...d_sign_esquire
#100 (permalink) |
From back in Sept - jwells393 posted this:
Here's the pickup:
1 Tapped Custom Seymour Duncan® Bridge Single-Coil Pickup Here's the switching: Custom-Wired 3-position Blade: Position 1. Full Output, Around 7.6K -- Punchy, Gutsy, Tele Lead Tone. Position 2. Tapped Output, Around 6.0K -- Brighter with Less Output. Position 3. Tapped Output with .022 Cap to Filter Out High-end -- Great for Rhythm. I think we discussed the fact that the neck pocket is 1/8 inch deeper than typical Fenders. Pretty cool - I'd like to check one out sometime.
Alright, hand over the Tele...and no one gets hurt! |
#101 (permalink) |
I have a coil tapped pickup in my reverse headstock Esquire, adds another whole variety of usable tones. On full output it is a pretty hot, vintage spec pickup, so it's crunchy and really rich in harmonics, has loads of sustain.
When it's tapped it's less output and just a more refined cleaner tone, great for slide or Robert Cray-esque crispy blues lead tones. I have mine wired with a push/pull pot. for the coil tap and then regular Esquire switching with paper and oil caps and carbon comp. resistor for vintage vibe. |
#102 (permalink) |
So, what do I do if I don't want any controls at all? I love the simple look for a simple boy. I'd just cover the hole up with a pickguard like similar to the ones for the tele's with the f-hole. But what do I do again regarding the wiring? Arlo....is anybody out there...
#103 (permalink) | |
#104 (permalink) |
Voided3, thanks so much. I can't wait to modify one of my geetars. There's one slight problem though...what are you saying. Does anyone have a drawing as this will be my first time opening up the guts of a geetar. So, think of me as your 2 year old. LOL
#105 (permalink) |
![]() Take the black (-) pickup wire and the wire that's soldered to the bridge (if there is one) and solder them to the negative lug on the jack, the one attached to the "sleeve" of the jack. Then take the positive (+) wire (usually red, yellow, or white) and solder it to the positive lug on the jack, the one that is attached to the "tip" connector (the part that is sticking out the farthest on the jack). If your pickup has a metal baseplate, then you probably don't need a separate ground wire since the screws take care of that; the negative wire from the pickup is probably soldered to this plate. Good luck! |
#106 (permalink) |
Dude, thanks. I'm going to go ahead and try it on a Squire Stand. Series Tele. It's a beautiful 2 tone sunburst. Very well finished and a truly beautiful paint job on it. If it was only a Fender, I'd be truly happy. I am a fender snob.
#107 (permalink) |
Nicely done voided3
Hugo,
You can buy prewired assemblies if you want to explorer the original Esquire wiring tones. But certainly wired direct will give you something hot as voided3 has draw. Plus there are so many different ideas with respect to Esquire switch and knob functions.
#108 (permalink) |
Esquirehoholic dude, what are you trying to do to me?????? You are the one who has gotten me all juiced up about Esquires. Thanks alot. I do have a Squire esquire, if that's possible? LOL. I have the Deryk Whibley sig. tele.
But what I want is to have one the way I want it to look. Is there any kind of a book on Esquires at all that would show me all the possiblities? That would be way cool. Any suggestions??? If not, I'll do what voided3 has shown me. My hat is off to him and I appreciate all the help. Direct me bro, and an Esquire will grow!! |
#109 (permalink) |
Here's a fun one with no Bassy filtered position that was posted a while ago.
This one you get straight through, just volume for preset level, or tone with volume. Pretty easy too: ![]()
#110 (permalink) |
I find that exchanging the entire resistor and cap with a single 0.005 cap to the ground yields exciting tones for a single sized humbucker with coil tap :) well, exciting to me at least.
#111 (permalink) | |
It's 106 miles to Chicago,we've got a full tank of gas,half a pack of cigarettes,it's dark and we're wearing sunglasses... |
#112 (permalink) |
Voided3
One of my all time favorite geetars was wired with volume only and one pup in bridge position. It was a screamer and it was nice to have a volume so I didn't have to unplug the guitar when I set it down. ![]() Not exactly what you are doing but the same principal and works. |
#113 (permalink) |
Arlo, excuse my ignorance but was that wired as the above wiring diagram? If not can you post a drawing of how you did that? I think Avril Lavine's Squire tele is done that way, isn't it? I'm getting very excited about this modding stuff. Very excited.
#115 (permalink) | |
Blank Tele Control Plate Jim |
#116 (permalink) | |
EMG comes with a prewired volume and tone knob with a jack attached and battery connector. |
#117 (permalink) |
I have a very similar guitar Arlo, my first ever modding project..
![]() Not very Tele/Esquire but it is actually quite a decent sound, I've considered building a Tele in the same way with just the single EMG humbucker, I have far too may project ideas are nowhere near enough money! |
#120 (permalink) |
Here is a Billy Gibbons making an Esquire sound pretty sweet.
http://www.youtube.com/watch?v=EzlKlyICaAs |
