GFS Surf Green Relic Tele - Telecaster Guitar Forum
Old September 12th, 2013, 01:51 PM   #1 (permalink)
Bazelevs's Avatar
Starting new relic project,
Lightweight Paulownia Surf Green body 3lbs.
Cheap chinese hardware and pickguard.
Squier neck.
ID:	197446   Click image for larger version
ID:	197447   Click image for larger version
ID:	197449   Click image for larger version
Bazelevs is offline   Reply With Quote
Old September 12th, 2013, 01:55 PM   #2 (permalink)
Bazelevs's Avatar
sand paper, steel wool pack, screwdriver, razor blade
ID:	197454   Click image for larger version
ID:	197455   Click image for larger version
ID:	197457   Click image for larger version
Old September 12th, 2013, 01:55 PM   #3 (permalink)
blowtorch's Avatar
I have that body as well, it's been sitting around for a couple years or so, I really need to slap it together with the neck and other stuff I bought for it
blowtorch is offline   Reply With Quote
Sponsored Links   #
Old September 12th, 2013, 02:02 PM   #4 (permalink)
Bazelevs's Avatar
I've used sand paper, salt water and antiperspirant that contains aluminium chlorid, that is.
ID:	197459   Click image for larger version
Old September 12th, 2013, 02:16 PM   #5 (permalink)
Bazelevs's Avatar
I was afraid that dimensions won't be correct, but neck fit the body well.
string holes drilled incorrect, also control cavity. I've expected this type problems from $50 body.
Old September 12th, 2013, 03:33 PM   #6 (permalink)
blowtorch's Avatar
Yes I've pretty much assumed as much, thanks though for verifying that. Nice relic-ing, looking forward to seeing it assembled
Old September 13th, 2013, 01:06 PM   #7 (permalink)
Bazelevs's Avatar
Old September 13th, 2013, 01:09 PM   #8 (permalink)
Bazelevs's Avatar
ID:	197548   Click image for larger version
ID:	197549   Click image for larger version
Old September 13th, 2013, 01:20 PM   #9 (permalink)
blowtorch's Avatar
that is looking great.
I wonder if you can darken the exposed wood some more, without too much trouble? sorry if I'm getting ahead of myself
Old September 13th, 2013, 01:47 PM   #10 (permalink)
Bazelevs's Avatar
I was thinking about it, but still haven't found easy way to do it.
Maybe someone can help?
Old September 13th, 2013, 01:52 PM   #11 (permalink)
blowtorch's Avatar
I think maybe I've heard about people using coffee grounds? and of course there is the old shoe polish trick, if it works on necks why not body scrapes?
Old September 13th, 2013, 02:01 PM   #12 (permalink)
waparker4's Avatar
If you want it to look dirty, how about... dirt ?
The body and hardware are looking great so far.
waparker4 is online now   Reply With Quote
Old September 13th, 2013, 02:33 PM   #13 (permalink)
Bazelevs's Avatar
I've applied several coats of tru oil on dings and 2 coats all of the body.
ID:	197556   Click image for larger version
ID:	197557   Click image for larger version
Old September 13th, 2013, 02:39 PM   #14 (permalink)
Bazelevs's Avatar
I'll try this on wood blank ) it should work
I've already tried tea + vinegar steel wool, but it doesn't looks naturally, it looks like see thru black finish, too grey
Old September 13th, 2013, 03:32 PM   #15 (permalink)
hesleptonstuart's Avatar
Try oil. I used motor oil, rubbed it on and left it to soak then came back and wiped any excess off. Really darkened the wood. "Fresh" wood really ruins a relic. Great job though, how's it sound?
hesleptonstuart is offline   Reply With Quote
Old September 15th, 2013, 01:46 AM   #16 (permalink)
Bazelevs's Avatar
thanks for advice, will try on next project.
I'm waiting for string ferrules and pickups to finish it.
Old September 17th, 2013, 02:15 AM   #17 (permalink)
Bazelevs's Avatar
I've ordered Tone Emporium TE-05 Boutique '52 Tele Pickup Set from Canada, anyone used them?
good specs for $60 set
Sand cast High Grade Alnico V rod
RWRP for hum cancelling middle position
Vulcanized Fiber Flatwork (bobbins), Nickel/Silver neck pickup cover.
Scatterwound, Cloth insulated push back wire
http://www.ebay.ca/itm/Tone-Emporium...EOIBSA:US:3160
ID:	198064   Click image for larger version
Old September 17th, 2013, 04:56 AM   #18 (permalink)
oramac7891's Avatar
I'd like to hear about the method used on the hardware, that stuff look great
oramac7891 is offline   Reply With Quote
Old September 17th, 2013, 10:12 AM   #19 (permalink)
marsh99's Avatar
This is gonna look great when it's done, looking forward to it!
marsh99 is offline   Reply With Quote
Old September 17th, 2013, 10:27 AM   #20 (permalink)
BigDaddyLH's Avatar
Wabi-sabi!
BigDaddyLH is online now   Reply With Quote
» Random Photo for Guests
1985 Alvarez Yairi DY90
Fender Logan Custom Guitars
