Minwax Wood Hardener for Soft Wood?
Would using a product like Minwax Wood Hardener prevent some of the scratches and dents in a soft wood like pine or alder? I don't think this would work well if you planned to stain or dye the wood, but maybe for a clear or solid color finish?
I am considering refinishing a strat I built with some fairly soft alder a couple years ago and don't want the new finish to dent as easily as the current finish. |
I have limited finishing experience, but I Would say no... I also would avoid minwax finishing products... IMO thy are more suited for staining your deck and not so much guitars or furniture etc... If you want a hard, durable finish, maybe just spray poly.
#5 (permalink) | |
Minwax spray (nitro) lacquer is very good and used by many here. If you are looking for a good wipe -on polyurethaneMinwax is very good and Finewoodworking agrees. Polycrylic is used sucessfully by some as agrainfiller. I like it for applications like trim in my wine cellarwhen I didn't want the solvent fumes. Their stains aren't bad though I can't always find the colors I want. My understanding of Minwax wood hardener is that it is primarily used for rotting or punky wood but I have never used it.
. "Something entirely new in the electric Spanish guitar field..." |
#6 (permalink) | |
I recently finished my first partscaster with Minwax Wipe On Poly, with great results. Very user friendly. |
I used the wood hardener on some spalted maple, and it never really hardened up. I doubt it would really do what you are wanting it to do, especially with the amount of surface area you are looking to treat (I was only doing a few strips in a body, and still used half the can and never got it where I wanted it).
MinWax Lacquer (rattlecan) and MinWax Tung Oil are two products that I use a lot , and both are good IMO
Herb I don't always play guitars , but when I do , I prefer tele's , stay twangy my friends |
I'm minwax fan myself. I really like the aerosol lacquer.
The websites does say the hardener is for decaying wood. Looks like I've got some testing to do. Thanks everyone for your responses. Last edited by tele_wah_fuzz; July 30th, 2012 at 01:40 PM. |
#10 (permalink) | ||
Please post the results! BTW, I have heard that the fumes from this stuff is pretty bad. Be sure to do it outside.
Hey johnnyboy99... I've been using MinWax products for years on guitars and think they are great.
I haven't heard of this "hardener" product, but if I can get my mitts on some I would definitely give it a try on some softer woods to see how well it works.
Some good info
http://www.htguide.com/forum/showthread.php4?t=32292 |
#14 (permalink) |
That stuff is intended to shore up heavily punked/rotting wood. At best it buys you time and maybe allows you to patch fill and then paint over the defect, as opposed to having to pull and replace the board.
On intact wood you will probably not get any significant degree of penetration so any effects will be restricted to the very surface, meaning it will be as prone to scratch/dent as any other finish option. |
#15 (permalink) | |
But it might be worth a try. Especially if you're not going to apply a stain and don't need for the wood to absorb any finish. |
#17 (permalink) |
I like minwax stuff as well.. I use their Tung Oil on all of the unfinished necks that I use. Great stuff.
And I would strongly recommend not putting that hardener stuff on good wood. Alder should be fine if you use a poly finish. Or just live with the scratches. I have an extremely soft bass body and after one gig, the buckle rash wore through the lacquer finish and gouged the crap outta the wood. I still use it like it is though :D |
#19 (permalink) |
So this might not be the magic potion to turn soft wood into hard wood. I will still probably test this out myself, hopefully this weekend. Someone mentioned dropping weights on the wood from a fixed height; that sounds like a good idea, I think I will try that.
#20 (permalink) |
My luthier buddy gives his acoustics a good slobber of hot hide glue as a first treatment once all the sanding is done. It has a remarkable effect on the wood , immediately tightening things up. It does go into the cell structure of the wood especially if you pre heat the wood. That gives the glue a longer time as liquid and it penetrates further.
As an alternative try using thin grade CA and just swipe it on with a foam applicator. Remember it gets hot as it cures and it smells a bit naughty also so plenty of ventilation. Several here have used it as a sanding sealer and as a pre finish with excellent results. See Flatfive 2012 challenge build. |
