Old June 4th, 2012, 03:05 PM   #1 (permalink)
orpheoet's Avatar
Tele build. Rounding edges?
I just received a Fender reject tele body. It needs some help. The main thing is its just rough cut. What's the best way to go about rounding the edges? There's also a small knot that needs filling. I'm doing a Mary Kaye finish so I'm hoping that will add a little interest to it:)
orpheoet is offline   Reply With Quote
Old June 4th, 2012, 03:48 PM   #2 (permalink)
Kennedycaster's Avatar
I use an 1/8" roundover bit in my laminate trimmer for tele bodies. As for the knot, you can use epoxy, DAP plastic wood, Durhams water putty, sawdust & glue, etc. Since it's going to be mary kaye, you really don't need to worry about the aesthetics of the fill as the edges will be opaque.
Bob
Kennedycaster is offline   Reply With Quote
Old June 8th, 2012, 07:16 AM   #3 (permalink)
Did you get that from a guy in silverlake?
Nareg is offline   Reply With Quote
Old June 8th, 2012, 07:18 AM   #4 (permalink)
A router?
The mighty oak was once a nut that stood its ground
PinewoodRo is offline   Reply With Quote
Old June 8th, 2012, 05:38 PM   #5 (permalink)
dsutton24's Avatar
Router and a 1/8" roundover bit.
Yet another hobby that is completely out of control...
Last edited by dsutton24; June 8th, 2012 at 06:19 PM. Reason: Not knowing what the *((*&% I'm talking about!
dsutton24 is offline   Reply With Quote
Old June 8th, 2012, 06:09 PM   #6 (permalink)
Originally Posted by dsutton24
Router and a 1/2" roundover bit.
1/2" is pretty extreme for a tele. It would end up more like a strat. 1/8" is the way to go on a tele.
Old June 8th, 2012, 06:18 PM   #7 (permalink)
dsutton24's Avatar
You're right... having one of those days where objects in the mirror are closer than they appear.
Old June 8th, 2012, 09:14 PM   #8 (permalink)
You too huh? It's always one of those days for me! ;-)
Old June 11th, 2012, 09:36 AM   #9 (permalink)
Make sure you carefull around that neck pocket with the 1/8 bit or you'll need more filling then that little hole on the horn!!!!
funkymann1 is offline   Reply With Quote
Old June 11th, 2012, 03:29 PM   #10 (permalink)
orpheoet's Avatar
Wilmington
Old June 11th, 2012, 03:30 PM   #11 (permalink)
orpheoet's Avatar
Thanks. Just bought the bit. I'll post pics once I get it routed.
Old June 12th, 2012, 06:37 PM   #12 (permalink)
orpheoet's Avatar
Thanks guys! 1/8 rounding bit on my kitchen counter did the trick! Neck pocket edges were not an issue, thanks for the warning.
Old June 12th, 2012, 06:51 PM   #13 (permalink)
orpheoet's Avatar
I think I found a neck for it. 79 strat maple fingerboard. Like new condition with tuners. 550. Thoughts?
ID:	130707   Click image for larger version
ID:	130708   Click image for larger version
Old June 12th, 2012, 06:57 PM   #14 (permalink)
nosmo's Avatar
550 What? Dollars?
Telecaster - The AK-47 of the guitar world. Some may think its ugly...but it works!
nosmo is offline   Reply With Quote
Old June 12th, 2012, 07:05 PM   #15 (permalink)
orpheoet's Avatar
Originally Posted by nosmo
550 What? Dollars?
Yup. High? Like I said, it's like new.
Old June 12th, 2012, 07:25 PM   #16 (permalink)
Waaay high. Looks like a "new" reissue neck. You can do so much better price-wise. Does it have to say Fender on the headstock? If not, why not try an allparts neck?
Bob
Old June 12th, 2012, 07:45 PM   #17 (permalink)
orpheoet's Avatar
It's not a reissue. Check out the serial number. That's why I think the price is ok. Though admittedly high. Here's the heel.
Old June 12th, 2012, 08:03 PM   #18 (permalink)
I still think it's too high IMO. After all, it's a '79, not a '69.
Old June 12th, 2012, 10:00 PM   #19 (permalink)
orpheoet's Avatar
I appreciate your opinion. Thanks. I plan on trying to talk him down a bit in person. But if it checks out I'll probably pay it. I have a 2010 strat with far far worse fret wear!
Old June 15th, 2012, 10:41 PM   #20 (permalink)
What about the heel shape difference? (Strat = rounded, Tele = square)
tstorer is offline   Reply With Quote
