Nitro Lacquer compatability
Anyone think that the T70 C 60 nitro gloss lacquer from sherwin williams would be compatible with Behlen Nitro that comes from Stew Mac?
I need a few more coats of lacquer on this guitar and I'm trying to find some nitro from a local store. I know that optimally I should obviously use the same product, but in theory should it work to mix products just so long as they are both nitro? |
#4 (permalink) | |
One note on Behlens its seems to take a much longer time to really harden (cure out) than the rest and that could cause problems with faster drying brands.
"All ya need are three chords and the truth" |
#5 (permalink) | |
#6 (permalink) | |
I do rattle cans (no cleanup) but Buckocaster has sprayed brushing lacquer (checkout his thread) and a few others have also with satisfactory results. The thing about brushing lacquer is that its formulated to have a slower drying time to allow the lacquer to flow out smoother after it comes off the brush. Now I have used all the previously mentioned brushing lacquers by brush redoing furniture and again Minwax all around for the same reasons I like their rattle cans. If you do spray bushing lacquer you may need to cut it with thinner so it will flow out of the gun and that would affect drying time. By what ratio would be hard for me to determine since humidity plays a role in the mix. Colt who has numerous posts is a great source of knowledge on these things also and I would recommend searching some of his posts.
"All ya need are three chords and the truth" Last edited by Flakey; May 21st, 2012 at 12:50 AM. |
Minwax says "Brushing Lacquer is specifically formulated to deliver excellent results when applied with a brush. It is not suitable for use in spray equipment." but all you have to do is thin it out then it sprays fine. If your gun has a 1.8 or bigger tip it probably wont need thinning. You can use the spray cans but you have to apply alot more coats to achieve any build cause it's pretty thin.
Sherwin Williams T 70 C 60 would be compatible with Behlens Stringed instrument lacquer.
Before I found Sherwin Williams lacquers, I was constantly trying new products, and trying to make Home Depot and Lowes products work. In my opinion, the Sherwin Williams products are superior to most lacquers. They dry harder and sand/buff easier than most lacquers I have used. I have sprayed both Minwax and DEFT brushing lacquers through a HVLP gun, and I can say with 100% certaintity, don't use DEFT. That stuff dries slows, its soft, its more chemically reactive, and it imprints easily. While the minwax is better, its still not as nice as Behlens or SW.
the now mandatory =====> |
#10 (permalink) | |
Gemini Precatalyzed Gloss Lacquer (1 gal) check it out: http://www.worldpaintsupply.com/gemi...lacquer-1-gal/ The price is right. under $30 for a gallon. Anyone tried this stuff? |
#13 (permalink) | |
The best lacquer I have ever used is Classic Instrument Lacquer by Mohawk who also makes Behlens. Reranch uses as well as alot of pro builders and furniture makers. Do a search for reviews. It's also not expensive and Mohawk makes everything you need for refinishing. http://magicwoodrepair.com/items/Lac...cquer/list.htm http://www.mohawk-finishing.com/catalog_browse.asp |
#14 (permalink) |
Nitro, etc
While talking with the tech reps from Rustoleum, who own WATCO, I was informed of Watco brushing laquer, which is nitrocellulose. They recommend up to 10% thinning with regular laquer thinner only. I am using it over a water based stain with a HVLP Tool Shop gun on a 24 3/4 scale neck for my MIM Strat. (USACustom Guitars mfg.) It goes on quite thick compared to 50-50% reduction and lays down nicely. It flashes off fast so dust does not seem to be much of a problem. In WI it is available from Menards, and maybe both Home Depot and Lowe's. It will get 1-2 more coats before curing and then maybe color sanding and rubbing, but it lays down smooth so it may not need rubbing. More as I get farther along.
#16 (permalink) |
Precat is more like a varnish and cures by chemical reaction rather than evaporation. It has a recoat time and wont burn in to the previous coat like nitro and you cant build it up too thick cause it will craze later on. It's alot more durable than nitro and used mainly for kitchen cabinets.
#17 (permalink) | |
Can lacquers not be both nitro and precat? |
#18 (permalink) | |
2) Call or email the company's tech support department. As mentioned before, only sporadically is "nitrocellulose" mentioned on the can - partially because it gets people confused when it's NOT there on other products that are perfectly compatible. Again, most products sold labeled as "lacquer" are acrylic nitrocellulose blends. Pure "nitro" is nasty stuff to manufacture and not very forgiving in application, plus it has very little film flexibility, which can be a real problem on motor vehicles (where many of the lacquer colors originated - right out of auto parts stores in Fullerton CA) AND musical instruments. Most of those who think they are applying "pure nitro" have never applied pure nitro. That being said, there are good and bad and many varities of each. Like Colt, I like the SW products - they stopped stocking them around here, though, so I use Valspar bulk lacquers now and Mohawk's rattle-can toners and specialty products (and sometimes gloss and semi gloss finishes when I feel lazy and don't want to use the HVLP...). At 5 or 6 bucks a can and with fine-finish spray tips I find myself getting lazier lately! ;-)
“No Chops – Great Tone” © |
