Old April 23rd, 2012, 09:10 PM   #1 (permalink)
Jupiter's Avatar
Applying CA to fill contoured surfaces?
Hi,
I'm planning to use CA to grain fill on an offset body that has some complex contoured surfaces. I know a lot of people use a credit card or suchlike to apply CA, but does anybody have a slick trick for applying it to contoured surfaces where a card won't work?
If only we could use our evil powers
For the good of mankind.
--Tito and Tarantula
Climbing Mt. Stupid since 1962
Jupiter is online now   Reply With Quote
Old April 24th, 2012, 02:52 AM   #2 (permalink)
Jupiter's Avatar
You can always tell the pioneers; they're the ones with the arrows in their chests. I'm gonna figure out a way to do this.
Old April 24th, 2012, 04:06 AM   #3 (permalink)
Blacque Jacque's Avatar
I think the problem you'll have is finding a flexible enough spreader that CA won't stick to. There aren't many materials it won't bond to, even fewer that will conform to the contours of a guitar body.
Maybe if you heated a regular plastic spreader then moulded it around the edge of the body or something with a similar radius ?
I'd suggest using a gel based CA rather than the low viscosity ones, and one with a longer cure time. Work on a small area at a time.
But most importantly, try it on some scrap first, no point wrecking a decent body for the sake of some cheap CA.
Now if you could spray it.............
Don't even attempt this ^^ it's unbelievably dangerous !!!
The nice thing about standards is that there are SO many to choose from
Blacque Jacque is offline   Reply With Quote
Old April 24th, 2012, 04:17 AM   #4 (permalink)
udimet720's Avatar
I used a spare piece of guitar string. You can use this to push a drop of ca ( liquid) around. Worked pretty well on a fabric topped strat where I had to fill the gap where the fabric ends right at the edge.
udimet720 is offline   Reply With Quote
Old April 24th, 2012, 05:27 AM   #5 (permalink)
Jupiter's Avatar
I was goofing around tonight with a YMCA membership card and high-viscosity CA; it worked pretty good in most areas, because I could bend the card, but for the 9 mm round over on the back, I might need to cut the card a bit. I think I got the right glue for this job. :-) It moved around with the card about the same as I saw the Zpoxy doing on YouTube. I like the way it sanded, too.
Old April 24th, 2012, 06:08 AM   #6 (permalink)
Jupiter's Avatar
Why would it be unbelievably dangerous to spray it? I can think of plenty of reasons why it might not work well, but it doesn't sound unbelievably dangerous.....
Old April 24th, 2012, 06:12 AM   #7 (permalink)
Because most CA cures by moisture catalysation, meaning it will cure on skin, eyes, lungs etc. It's probably more dangerous than 2 pack paint.
Old April 24th, 2012, 10:01 AM   #8 (permalink)
Just use some (decent quality) kitchen paper. Or a fingertip, really. As long as you keep moving, it won't stick to the wood. It's how I apply CA to all my spalt maple pieces to stabilize, never had any problems.
mattia is offline   Reply With Quote
Old April 24th, 2012, 03:34 PM   #9 (permalink)
Vizcaster's Avatar
Doesn't Buckocaster just smear it on with gloved fingers?
Old April 24th, 2012, 04:08 PM   #10 (permalink)
rip_topaz's Avatar
I use the back of a piece of wet/dry sandpaper. Be careful, though. It won't stick to the paper right away, but it'll stick to everything else.
rip_topaz is offline   Reply With Quote
