Old March 17th, 2012, 04:06 PM   #1 (permalink)
gitlvr's Avatar
Help with grain filler prep.
Hi!
To what grit paper would you sand your body before filling the grain?
I'm assuming you'd sand it to the final(finest) grit you're planning prior to finishing, and then go on to grain fill, but I don't want to make any assumptions.
Mike
The only thing necessary for evil to thrive is for good men to do nothing.
gitlvr is offline   Reply With Quote
Old March 17th, 2012, 04:13 PM   #2 (permalink)
flyingbanana's Avatar
Originally Posted by gitlvr View Post
Hi!
320. Especially when final sanding just prior to painting, because you don't want the surface so smooth that paint will have a tough time adhering to it.
flyingbanana is offline   Reply With Quote
Old March 17th, 2012, 04:25 PM   #3 (permalink)
Colt W. Knight's Avatar
I sand to 220, apply a coat of sealer. Then grain fill.
the now mandatory =====>
Old March 17th, 2012, 04:32 PM   #4 (permalink)
gitlvr's Avatar
Thanks, guys.
Colt, if I remember correctly, you use vinyl sealer. I plan to use deft sanding sealer(or the StewMac equivalent), since I have no spray facilities. That stuff is basically a heavy sealer(full of solids). Do you see any difficulty in grain filling after using this?
If so, I will seal with a few coats of clear lacquer before filling.
Mike
Old March 17th, 2012, 04:38 PM   #5 (permalink)
Thanks, guys.
Nope, I use to brush on Deft Sanding Sealer before grain filling before I got into Sherwin Williams products. Worked nicely. While I do not like DEFT Lacquer, DEFT Sanding Sealer always performed very well for me.
Old March 17th, 2012, 04:52 PM   #6 (permalink)
gitlvr's Avatar
Thanks. That's all I needed to know!
Much appreciated, both of you.
Mike
