Old April 12th, 2011, 05:42 PM   #1 (permalink)
Sanding / Dyeing Zebrawood
Good day,
I have a Tele body ( Ash body with Zebrawood top ). I've sanded the Zebrawood top 150, 220, 240, 320. In dyeing a practice piece of Zebrawood with a water based aniline dye I've noticed that the pits in the wood, even after sanding, are not always taking the dye so well. I end up with a very nice tint but the pits are the color of the un-died wood.
Would anybody have suggestions for a uniform dyeing job?
Thanks in advance,
Mark
Mark Beattie is offline   Reply With Quote
Old April 12th, 2011, 06:06 PM   #2 (permalink)
piece of ash's Avatar
Has the wood ever had a finish on it before?
piece of ash is offline   Reply With Quote
Old April 12th, 2011, 07:04 PM   #3 (permalink)
davmac's Avatar
Are you dampening the surface before applying the dye? I saw this as a tip to ensure a more even coverage of the dye. The video and source of the tip http://www.finewoodworking.com/Skill....aspx?id=30182
davmac is offline   Reply With Quote
Old April 12th, 2011, 07:35 PM   #4 (permalink)
SacDAve's Avatar
You might be better off tinting the clear. Myself I would just clear Zebra wood just leave it natural
SacDAve is offline   Reply With Quote
Old April 12th, 2011, 08:06 PM   #5 (permalink)
Thanks for all the replies so far. The piece is new and has never had a finish on it. As I've mentioned I've sanded to about 320 but no matter how much I sand there are always slight pits in the wood ( I'm thinking that's a characteristic of the wood itself ). I really like the combination of dyes that I've tested ( Antique Cherry and Russet Amber ) so I'd rather not finish clear for this particular body. As well, I only have a rattle can of Nitro so not sure that tinting a lacquer is an option without other equipment.
I've watched the video and will test another application and wet the wood before I stain.
Thanks again for your replies.
Old April 13th, 2011, 09:05 AM   #6 (permalink)
Rhomco Guitars's Avatar
May I suggest
May I suggest you look into using a toner in lieu of or even jointly with the stains. It is available in aerosol from several sources but I use Mohawk brand. You use it after the surface is sealed and flat to get the color depthness you want and then clear coat over it to get the desired thickness for final wet sand/buffing. Works very well and the only trick is to go slow and easy with the toner as it is quite thin and will run if you get in a hurry.
Just a suggestion,
Rob
"If I won the lotto... I would be a full time Luthier until the money ran out". Coffee, Sand Paper & Lacquer Fumes..... now thats a good day!
www.rhomcoguitars.com
Rhomco Guitars is offline   Reply With Quote
Old April 18th, 2011, 10:38 AM   #7 (permalink)
Please post some pics when your done! Here is my Zebrawood Tru-oiled T build..
Movingpictures is offline   Reply With Quote
Old April 25th, 2011, 07:26 PM   #8 (permalink)
spook777's Avatar
+1
Just out of curiosity, how come you aren't grain filling it ? As far as rattle cans go...I feel you...thats what I'm using too. Maybe spray it into a small container (I'm using a detergent measuring cup for my little things) and then add the dye...dab it into the holes (I bet there are hundreds) and then scrape it /sand it flat again. Wouldn't that solve it?
BTW a boxcutter razor makes a great mini scraper.
Here's the one I'm building for my brother in law...nitro satin finish. I see lots of those little holes in his too.
spook777 is offline   Reply With Quote
