Just another grain fill thread
I didn't want to hijack Otter's thread, so I though I would just post some pics of how I grain fill.
These are some older pictures before I really got the "hang" of it, but they illustrate the concept well in my opinion. This is the procedure I follow now because it yields the best results for me. 1. Sanding Sealer - I spray brushing sanding sealer because its thicker, and cheap. Allow it dry, sand flat with 220. 2. Sanding sealer, allow to dry, buff with steel wool. 3. Thin grain filler to consistency of snot, and massage into wood. 4. When it starts getting pasty feeling, I squeegee excess away. You can actually reuse this stuff if you don't get it dirty. 5. Allow to dry long enough to develop a film, or as Otterhound put it, a hazy appearence. I think hazy is a better term than film, so I am going to start using that now. 6. When the haze appears, I buff with a shop towel or burlap. And I let that dry for an hour or so. 7. Then I spray another coat of sealer, allow to dry, lightly sand with 220. 8. Another coat of sealer, allow to dry, buff with 000 steel wool. Most woods I only need to apply grain filler once since I have adopted the system of using more sanding sealer, but I have done it up to three times. Any way pictures. ![]() ![]() ![]() ![]() 7.
the now mandatory =====> |
Then some more sealer.
![]() I don't have any finished pictures, sorry guys. I dropped the damn thing and had to strip it and make some repairs. I haven't refinished it yet. But it was dead flat and pretty before I dropped it. It landed on the vice, bounced off the corner of the table, smashed into my scroll saw on its decent, and landed on concrete with a bunch of scrap metal pieces laying around. The neighbor actually came to check on me when he hear the curse words echoing through the holler.
Same way, just have to use a shorter squegee or a floppy squegee. You'd have to just take several passes instead of one quick scraping mechanism. No big deal, I am just removing excess filler. I have wiped it off with a gloved hand before when I accidentally glued my scraper to the table.
I should add, that when I use the scraper/squeegee, I am not digging in and making sure I get everything. If you scrape too hard, you will just drag the filler out of the pores. This is why I don't like sanding grain filler. I just want to get rid of excess filler so the remaining filler can dry, and I can buff it flat.
#11 (permalink) | |
Oh, I forgot to mention. My favorite grain filler is actually Birchwood Casey Sealer/Filler. It is really cheap and pops the grain. The only draw back it it is a little messy and requires two or three applications. However, you don't need any sanding sealer before application.
#13 (permalink) | |
I am impressed that you are able to do your grain filling in one step. I have heard others mention locking the filler in with S&S so I think that's what helps. A few questions about your technique: 1. Your first coat of S&S- are you using it to start to fill the pores or is it more to help the filler grab the wood like a primer does? 2. When you buff the S&S are you trying to level it? Or remove it all together from the top surface of the wood, leaving it in the pores only? Why steel wool and not sandpaper? 3. 4. I think the squeegee process is where some of us are taking too much filler away. You said you use a light touch. Do you hold your scraper perpendicular with the body or at a low angle that is pushing the filler down into the wood? 5. 6. When you buff the hazy filler, are you trying to get all of the excess off from the top surface? That filler is tough stuff once it hardens. It's difficult to get the surface cleaned off in the buffing stage without pulling the filler from the wood pores. Advice? Thank you for posting these instructions. This is one of the more challenging aspects of finishing for some of us.
. "Something entirely new in the electric Spanish guitar field..." |
#14 (permalink) | |
The key to this whole process is you are taking it in gradual steps. Not attacking it all at once. The purpose of grain filling is just to fill the pores. You get everything level by wet sanding the lacquer. My extra steps of SS some consider extra or unecessary act as little buffer/filler/leveling coats so you don't have to fool with the grain filler as much.
Thanks for this. Thread like this are just what n00bs like me look for. It's good that old hands like yourself have the patience to pass along knowledge that's so often taken for granted.
I have a bit of experience working with gunstocks, which involves mostly stains and oils, also done my share of automotive body/paint jobs, whereas epoxies are the norm these days. Guitar work seems to encompass a bit of both - some of the same woodworking/spraying techniques but different materials. It's been years since I worked with laquer. |
#16 (permalink) |
Hi Colt,
Have you used this process on a body that has been dyed. That is, dye hand rubbed into raw wood? Wouldn't all the S&S and grain filler discolour the dye? I still need to find a good way to grain fill ash after hand rubbing dyes? I tried just clear coats, but I ended up spraying around 20 odd coats to get it level. Perhaps somehow add the dye to the grain filler? Cheers. |
#17 (permalink) | |
Grain filler does have a color, so you need to dye it to match or use a contrasting color that would look good. For example. Say you want a transparent red finish on your ASH body. 1. Finish sand to 220. 2. Raise the grain, then lightly sand back to 220 or buff with steel wool. 2. Dampen the wood, and rub in(Massage) a quality red dye (like Transtint) 3. Allow to dry. Then apply a coat of sealer. And lightly sand it smooth. You don't want to sand through. Repeat. 4. Apply grain filler. You can either add black dye to the filler to gie you a nice contrasting black grain on the red, or dye the grain filler red. ( The example I showed above was actually died brown, it was a natural colored grain filler). 5. Apply a sealer. Allow to dry, and sand flat with 220. 6. etc. etc. Of course, the easier/better solution in my opinion would be to use tinted lacquer over the grain filler/sealer to get the color you are after. It is my experience it is far easier to control the color spraying it on as a toner coat.
#18 (permalink) |
Guys, a build thread recently said he ran out of sealer/filler and just sprayed his poly clear as a sealer.
Other than, I imagine, the wood drinking it, is this a realistic option? As a (home) experienced car/motorcycle spray painter this appealed to me more than the grain fill, sanding sealer methods of which I have zero experience with. I was thinking a 2 pack clear for chemical curing......then perhaps a 2 pack primer to build smoothness (I guess grain fill?). This is for a solid colour finish. |
#19 (permalink) | |
#20 (permalink) |
THANKS Colt.
I think my sealer has a slight brown / muddy tint to it. I might look for an alternative. I appreciate the time you have taken to type out these instructions. Cheers. |
