Old May 21st, 2010, 02:26 PM   #1 (permalink)
txspreacher's Avatar
Lacquer...nitro vs. waterbase
I tried search and couldn't find what I was wondering. So I have a couple of questions....
1. Do successive coats of water-based burn in like with nitro?
2. Is the "30 days in the hole" still a requirement or is the gas off time shorter?
Thanks in advance.
It ain't the years, it's the miles....
- Greg
txspreacher is offline   Reply With Quote
Old May 21st, 2010, 05:29 PM   #2 (permalink)
*chirp-chirp-chirp*
- Greg
Old May 21st, 2010, 05:35 PM   #3 (permalink)
SnorkelMonkey's Avatar
This sparks my interest as well.
SnorkelMonkey is offline   Reply With Quote
Old May 21st, 2010, 07:37 PM   #4 (permalink)
LuvN Guitars's Avatar
Thanks in advance.
This info is from Michael Dresdner's book "The New Wood Finishing Book", he's a furniture finisher but the info in it applies to guitars in most cases, there's even some pictures of staining a maple top Tele body to "pop" the grain. There's a wealth of information on finish types and how to achieve finish effects in the book.
Waterborne coatings- Cure time for satin rub- 7 days, for gloss rub- 1 month.
Waterborne finishes do not melt in.
LuvN Guitars is offline   Reply With Quote
Old May 22nd, 2010, 09:27 AM   #5 (permalink)
Thanks, LuvN Guitars.
- Greg
Old May 22nd, 2010, 11:23 AM   #6 (permalink)
This is fundamentally inaccurate. WB lacquer does melt in. In fact, Target Coatings' (supplier to StewMac) lacquer is claimed to have indefinite melt in. You can definitely get a gloss rub after about a week, but it might work better after a month. I didn't wait that long, though.
I have seen witness lines in WB Minwax wipe-on poly when I went too long between layers- that stuff needs to have each coat within a couple of hours or less of the previous- basically as fast as the last coat has dried, do the next. I have never seen witness lines on the two bodies that I have done with TC lacquer, regardless of how long I waited between coats. Just be sure that you have a consistent finish before you go to the clear coat, meaning no shiny patches.
930vet is offline   Reply With Quote
Old May 22nd, 2010, 03:17 PM   #7 (permalink)
So it sounds like in your personal experience WB is pretty forgiving to work with. My current project is already moving along in nitro, but my next one may just have to be WB. Thanks to all for the input.
- Greg
Old May 22nd, 2010, 03:42 PM   #8 (permalink)
Great info thanks!
Old May 23rd, 2010, 05:17 PM   #9 (permalink)
For musical instruments, stick with nitro lacquer. WB options are fine for furniture, but even there, they don't measure up to the beauty of nitro lacquer. For your beloved Tele project, there is only one option!
Macpaulster is offline   Reply With Quote
Old May 27th, 2010, 01:27 AM   #10 (permalink)
old_picker's Avatar
i disagree with this - i found WB lacquer very friendly to use, extremely low toxicity, not flamable and clean up in water - no stinky inflamable toxic fumes
i have built some killer guitars finished wb lacquer - produces an excellent high gloss finish as good as any i have seen done in nitro, two pack, poly or whatever
if you feel you want to try it go right ahead - nitro is NOT the only option for your beloved tele
ray
old_picker is offline   Reply With Quote
Old May 27th, 2010, 02:09 AM   #11 (permalink)
Ray, you make a valid point. I agree with you that if the above things you mention are of paramount importance then WB is an option.
However, if you want the most beautiful, and best sounding guitar finish, then you've got to deal with the not so friendly, higher toxicity, flameable, clean up issues, and toxic fumes of Nitro Lacquer! But there is simply nothing as beautiful as a hand rubbed lacquer finish. WB is not even close. I'm not saying WB can't look good, but in a side by side comparison, well, there just isn't any.
Old May 27th, 2010, 12:59 PM   #12 (permalink)
Colt W. Knight's Avatar
This is also innaccurate. Some of the high end strat and tele builders like Suhr use WB lacquer with just as great a luster as Nitro. Furniture guys tend to use nitro/acrylic catalyzed formulas for their use. They have quick drying times and high solid base so they only have to spray a few coats. These mixes do not shine up anywhere near Nitro based lacquers, but they hold up to drink rings and bathroom moisture. Expensive automotive acrlyic lacquers will buff out crystal clear, and have a shine superior to Nitro.
the now mandatory =====>
