Old January 10th, 2010, 09:25 AM   #1 (permalink)
Grain filling Ash with wet sanding with oil? I need info.
I read on this forum somewhere that instead of using grain filler i can wet sand oil and the dust will mix with the oil and fill the grain. I did search and cannot find that post.
Will someone fill me in on this method? will it work with ash? what is the proper way to do this?
I need all the info i can get.
Thank you.
Guitartom_ca is offline   Reply With Quote
Old January 12th, 2010, 07:26 AM   #2 (permalink)
ramseybella's Avatar
I only use grain filler.
ramseybella is offline   Reply With Quote
Old January 12th, 2010, 08:47 AM   #3 (permalink)
Home Grown Tele's Avatar
You can do that with Tru-Oil. Try posting that question over on ReRanch. Several members there have used that technique in the past.
Home Grown's MySpace Page
Chris Leger- "I freeze all the electronic parts of my guitars. It gives them a piquant, morsellated quality, with none of the unctuousness of more garrigue components."
Home Grown Tele is offline   Reply With Quote
Old January 12th, 2010, 09:13 AM   #4 (permalink)
originalmatthew's Avatar
It's pretty simple but requires some patience. I start with a 400 gr. wet or dry paper, and just enough oil to keep a nice skim coat on the wood. I sand with the grain, a section at a time making sure to overlap the sections. You will see the oil start to get gummy and wood colored. Add a few drops and keep going. When it looks like most of the pores are filled, stop and let the oil set up for about 10-15 minutes. I then use a credit card as a scraper and scrape off the excess going diagonal to the grain. Let the oil dry, (overnight for me) sand lightly with a block and some 600 gr., and repeat the process as many times as necessary to fill all the pores. If you tilt the body around in a light, you can see what still needs filled. After the filling is all dried, then you can start building coats to get the desired sheen.
Let someone else do the white paint job!
originalmatthew is offline   Reply With Quote
