Old December 15th, 2009, 07:26 PM   #1 (permalink)
need help: cracks in finish on tele
I recently bought a 62 reissue tele body in sunburst that has numerous cracks on the finish. what is the best approach to minimize or repair this ?
should i use a very fine grit sandpaper to buff it out ?
joshcamp is offline   Reply With Quote
Old December 15th, 2009, 08:17 PM   #2 (permalink)
pics
here is a pic that show some cracking in the finish tho i can't seem to capture the extent of the cracking without proper lighting (ie - there's more than the pic shows)
Name:  tele body finish cracks 1.jpg
Old December 15th, 2009, 08:58 PM   #3 (permalink)
K-Line's Avatar
Looks more like someone started to razor check it. I think that these were nitro over poly so cracks like this is suspicious.
Chris Kroenlein
K-Line Guitars, LLC.
www.k-lineguitars.com
314-276-7402
k-lineguitars@sbcglobal.net
K-Line is offline   Reply With Quote
Old December 15th, 2009, 09:04 PM   #4 (permalink)
not sure... got it this way. the back has more of these cracks. can't imagine why someone would intentionally make these cracks...
Old December 15th, 2009, 11:40 PM   #5 (permalink)
mellecaster's Avatar
Does it say TL-62 in the Neck Pocket ?...May be a Japan Body...finished in Poly...that's what the cracks look like from your pics ?
Old December 16th, 2009, 12:19 AM   #6 (permalink)
it reads: C 62B/1 (hard to really make it out but that's what i can gather) from the neck pocket.
Old December 16th, 2009, 12:45 PM   #7 (permalink)
i'm thinking i could use sandpaper to sand off the clear top coat (?) without damaging the sunburst undercoat, until the cracks disappear. then i could refinish with a clear topcoat of poly or nitro. does this make any sense ? or, am i going about it all wrong ? i don't want to completely refin the guitar -i.e., down to the wood. i like the sunburst !
Old December 16th, 2009, 06:42 PM   #8 (permalink)
Old Cane's Avatar
"i'm thinking i could use sandpaper to sand off the clear top coat (?) without damaging the sunburst undercoat"
I'd think the same thing until I tried it once. Now I don't think so. You won't know where the clear stops and the sunburst starts unless you have some of those x-ray glasses they sold in magazines.
