Applying a glitter finish to a guitar
Hi all.
I am about to embark on a project where I want to glitter finish a Tele body. My intention is to use spray can clear-coat and simply sprinkle the glitter onto the tacky surface and build up the finish that way. I have a few questions which I hope you can help me with: - will that approach work? - do I need to use special glitter or would even arts/crafts glitter be OK? - am I crazy to even attempt it? (I realise my taste is certainly called into question!!) Any tips, tricks, war stories? Thanks guys.
www.bigtimecharlie.info |
If you haven't already, check out the Emeraldcaster project over in the build forum.
The basic technique is applying the finish then putting the flake in while the finish is still wet. once it drys you put more finish on top. Is that what you were describing?
If it don't twang then it ain't worth havin'! |
Yes there is a ton of information on the Emeraldcaster thread but it is so huge that it needs an index to help people find things.
All the info is there in great detail and with photos.
Turn it on, turn it up, turn me loose. |
| Glitter and Twang at the Musuem | WickedGTR | Bad Dog Cafe | 8 | May 4th, 2009 09:55 AM |
| Tribute to Mick Ronson -- glam rock guitar instrumental glitter | wnorcott | Twanger Central | 5 | October 5th, 2008 11:56 AM |
| Help applying Tweed | Markl8 | Amp Central Station | 4 | July 12th, 2008 03:23 AM |
| Krylon Glitter Shimmering Silver | lostpick | Tele-Tech | 1 | April 6th, 2008 12:38 AM |
| Applying a new finish to a neck... | Atticus 3 8 97 | Telecaster Discussion Forum | 6 | March 11th, 2008 04:45 PM |
