can I just paint over orig. finish to change color?
Guitar body isn't nicked or dented and the original finish is in very good shape. No gouges, scratches, etc. It's painted red, I want seafoam green.
So why remove the original finish? The wood's already sealed and has several base coats of color, no? What's wrong with just sanding the existing finish, applying appropriate primer, and applying new color? Thanks. |
Nothing, a lot of folks do that. Even fender has done it before.
-"You do not merely want to be considered just the best of the best. You want to be considered the only ones who do what you do" J. Garcia |
Just sand enough to get a micro-scratch pattern for the new finish to adhere. Probably not necessary to go any rougher than 600 grit (400 and especially 320 can leave scratch marks that show through some lacquers and paints). Then wipe it down with denatured alcohol (or if it's poly you can use lacquer thinner without cutting into anything) in order to get rid of any grease or dirt left behind from the old surface and handling. A mist coat of primer wouldn't hurt before switching to your new color. Hopefully it will cover without the red underneath affecting your surf or seafoam color. My daughter's favorite, by the way. Good luck and please post pix.
VENDOR
Original Sunburst......Had alot of fine polish scratches and a few deeper scratches.
![]() Stripped her down....lightly sanded surface with 320. Wiped down with Naptha. Used a self etching primer................ ![]() On to Color coat with the first 3 passed fairly dry.......... ![]() Then wetter coats and clear coat..................Now ya have a unique guitar that the cool kid with the goofey haircut doesn't have............
![]() Jeffro' at Southern Ill Electrics 618-643-2406/618-308-0223 God Bless Les and Leo. |
Info on how Fender did it in the old days:
Here's a lot of great information on how Fender painted and repainted guitars in the old days: http://www.provide.net/~cfh/fenderc.html
I'm always impressed on how people like Leo Fender and Henry Ford developed methods of cutting costs with mass production. |
VENDOR
I used it because of the already painted surface even though I did scuff it with sand paper.......good bonding,my new CC sticks better.
This one had alot of metal flake, and I wanted flakes to pop....to get the best application,there is a ceratin techique and I want it to stick and no problems.....NO case queens....play em'.............But don't take my word for it......its best for one to do his/her own research rather than believing what you might read on a forum somewhere. ![]() ![]() This one pops really good........here she is after assembly and scraping the bindings.......... ![]() Prep is the key.....its the little things before the CC is applied that renders a good result.........all depends on how much you want to do before hand.
There are a couple fo things you have to consider before you paint over an existing finish...
What is the current finsih type that you are covering over and what type of finish are you going to use to cover old finish?? So many people have not taken these into consideration when they refinished their guitars. Sure the new finish will stick at first but if the two finishes aren't compatible the new finish will eventually start peeling off as it cures. I have had a lot of repairs brought to me to fix where this happens and also where the new finish started bubbling. |
#10 (permalink) | |
VENDOR
Sounds like it was a prep problem.
The last one brought to me to repair had a nitro original finish, he had the paperwork from when he bought the guitar new. He told me he did a light sanding on the entire body and then used acetone to clean it and then he used a tac cloth to wipe it before he applied the new finish. He said the new finish was a laquer. He said that after about 6 months the new finsh started peeling off the old finish.
VENDOR
Hmmmmmm.......Lacquer is pretty forgiving.
What was your method of repair ?
#14 (permalink) |
VENDOR
Are ya still having trouble with that Nitro not taking ?
I may have a fix...I'll answer in your other thread.
| 2 color paint job question? | Flynman | Finely Finished | 4 | October 24th, 2009 05:45 PM |
| Custom color paint problem, help! | robt57 | Tele-Tech | 13 | August 29th, 2008 02:05 PM |
| Possible to change color from wine color to butterscotch? | Tsuekasa | Telecaster Discussion Forum | 7 | June 5th, 2008 09:53 PM |
| thought of a paint color for my new build | Shelby21 | Telecaster Discussion Forum | 1 | May 5th, 2008 11:05 AM |
| how to paint a see through color | flupke | Telecaster Discussion Forum | 21 | May 26th, 2005 10:23 AM |
