Old November 5th, 2009, 02:04 PM   #1 (permalink)
telepath's Avatar
Help! - Pink Tele! - advice on 'shell' or 'paisley' options?
Hi,
I have a (very!) pink one ..
Tele that is ..
Its a T-style copy - unsure of 'breed' as headstock had been sanded a little. It may have been a 'Wesley', FWIW.
Hardware has been mildly modded a little since the pic below, but the colour is the same and I essentially can put it back to 'standard' tele set-up.
Question is re the colour.
I assume its a poly finish, its thick and shiny.
I'd like to do one of two things!
1. soften and lighten the finish to closer to a 'shell pink' - or close enough.
or
2. put a paisley pattern ('decal' - if such a thing exists) on top of it.
In natural light its not far of the base colour of a Paisley Fender.
How might I go about option 1. ?
(I really wouldnt mind at all if it ended up looking a little roadworn in the process ;) )
and is option 2. a possibility for a relative novice at finishing?
(I'm fairly competent and patient)
Pic below of what the finish looks like from a photo I took prior recent (reversible) hardware mods:
Any advice would be real appreciated.
Thanks!
[ebaY sniper, enthusiastic scavenger of underrated Squiers, ham-fisted assembler of Partscasters]
telepath is offline   Reply With Quote
Old November 5th, 2009, 03:42 PM   #2 (permalink)
varakeef's Avatar
There's no Paisley stickers or decals commercially available. There's however some guys who try to sell Paisley papers around 100 buck a sheet.
Then there's an option to make the sticker yourself, stick it on silvery or golden backing glued on guitar and then clear coat it.
Which is what I did...
I got the pattern from the scan of original guitar, made a file and got it printed on clear window sticker at the local shop for 15 euros a sheet (and after I printed some more the price dropped to 12 euros). The backing is gift wrap paper, cost around 3 euros per 3 metres...
If you remove the noisy stuff inside the piano it makes a great house for a dog.
varakeef is offline   Reply With Quote
Old November 6th, 2009, 04:05 AM   #3 (permalink)
telepath's Avatar
Looks good!
Thanks for that varakeef,
I did imagine that 'paisley-ing' might be a bit of a job, perhaps a bit much for me.
So I guess what I want to do, is 'lighten' up the current pink finish.
Still looking for a bit of advice here then !
if I sand it flat, and then tint it with a milky clear coat, and then flat that back a bit, would that get closer to shell pink (from a kind of 'pepto bismol' pink)?
Any assistance greatly appreciated.
Thanks!
'62 Shell Pink Tele Advice CapnAHav Telecaster Discussion Forum 19 July 10th, 2009 05:22 PM
GFS Shell Pink Tele Danno Telecaster Discussion Forum 11 January 16th, 2009 11:37 AM
Shell Pink '96 MIJ Tele on Ebay trucks Telecaster Discussion Forum 2 January 2nd, 2008 12:50 AM
Shell pink MIJ tele GuitarJonz Telecaster Discussion Forum 11 April 18th, 2007 08:08 PM
Almost shell pink, but not a Tele FraKo Bad Dog Cafe 10 September 14th, 2006 05:05 AM
