Old November 5th, 2009, 12:51 AM   #1 (permalink)
Affinity Tele and the Dreaded Poly Finish
Hi folks, first post here. I've been poking around through several threads and haven't come across anything that answered the question I have, which is: can I sand down the thick coat of polyurethane on my Squier Affinity Tele, just to take some of the gloss of of it, without having to strip it all the way down and refinish it? I am not necessarily looking to "relic" this guitar - an obviously much debated topic here - but just to knock down the thick, shiny coat a bit. If I were going to do this, would I wet sand with increasingly fine grades of sandpaper? And would I then need to give it a coat of nitro or could I leave it as is?
Thanks, Craig
craigdallen is offline   Reply With Quote
Old November 5th, 2009, 01:00 AM   #2 (permalink)
voided3's Avatar
My Affinity that I modified actually had a pretty thin finish on it by Squier standards. I found this out when I put a tummy cut in it; it actually seems thinner than the finish on my MIM Standard Strat, but that's just this one guitar. Basically, there won't be any tonal advantage to sanding the finish, especially if you put more finish (nitro) on afterwards, but if you want to make it a matte finish, I would start with 800 grit wet sanding and work your way up through the finer grits.
'06 MIM 50's Esquire w/ B-Bender and neck pickup added
Squier/GFS humbuckered partscaster
Home-made 2x6 pine body Esquire
...and a bunch of other stuff.
voided3 is offline   Reply With Quote
Old November 5th, 2009, 01:55 AM   #3 (permalink)
Would 0000 steel wool be best? I would answer, but I have never had the guts to mess with a guitar's finish.
Joefaity is offline   Reply With Quote
Old November 5th, 2009, 02:03 AM   #4 (permalink)
voided3's Avatar
I used 0000 steel wool on a cheap Ibanez bass once and it leaves a very noticeable "grain" from your sanding patterns, so if you work in only one direction, it'll look fine, but wet sanding in a circular motion gives a more even matte finish (though the directional "grain" can be a cool look, too).
Old November 5th, 2009, 02:03 AM   #5 (permalink)
Stuco's Avatar
If you want a matte finish, then get some 0000 steel wool and rub away. That method would take a long time to take any thickness off though. What's wrong with shiny finishes?
-"You do not merely want to be considered just the best of the best. You want to be considered the only ones who do what you do" J. Garcia
Stuco is offline   Reply With Quote
Old November 5th, 2009, 02:22 AM   #6 (permalink)
thejerk's Avatar
Use a scotch brite scouring pad (like the green part that comes on the back of a green and yellow sponge). Others have done this with great success, some using power tools to help. Google will help!
These machines kill fascists:
{ 2008 AL3000M HSB Plain Top }{ 2001 Taylor 310KCE "Legends" }{ 2009 Fender Standard Telecaster }
{ 2009 Squier Classic Vibe Duo-Sonic }{ AL2500 FR White }{ 2009 SX SST PBU }
{ Fender Super Champ XD }{ Roland KC500 }
thejerk is offline   Reply With Quote
Old November 7th, 2009, 10:50 PM   #7 (permalink)
What a coincidence, my butterscotch Affinity is sitting next to me with a coat of polishing compound on the back. Previously I had been rubbing it with oooo steel wool. The back is safe enough to experiment on. It's a little too matte for my tastes , that's why I' now trying the polishing compound. An experiment only, I'll have to take the thing apart to go further.
BTW, once someone on this forum said that the finish was too shiny, it got under my skin. I once was happy, forums bad.
Results are in, finish was a bit streaky due to uneven rubbing I guess. I applied a coat of car wax and that evened things up a lot, the finish on the back is now a nice satiny semigloss, warmer and more natural than the high gloss. I'm encouraged and most likely will continue when I take the thing apart ( I want to shield the cavities and mess with it a bit) I'd post pics but the ones I took are worthless.
61fury is offline   Reply With Quote
Poly vs. Nitro Finish for a Parts Tele mwittoesch Finely Finished 1 March 24th, 2009 05:38 PM
body new finish over poly finish fernando Tele-Tech 10 December 23rd, 2008 09:09 AM
Squier Affinity neck finish: most likely poly? blacklove Tele-Tech 10 March 3rd, 2007 04:20 PM
finish questions - poly over poly? flapjack Tele-Tech 5 October 20th, 2006 09:07 PM
What would do this to a Poly finish? RichardL Telecaster Discussion Forum 3 May 19th, 2003 06:38 AM
