Run in sand and sealer....
Hey Crew,
I've been delayed on my tele project for a while. My neck is in good shape. Done with s&s and neck amber today. Body has taken longer. This week I finally got the grain filler in a decent condition to move on. Today I shot S&S and got a run coming from one one of the edges and ran a little onto the front surface. Went ahead and let it dry, waited 20 and then shot a thinner 2nd coat. The run is still visible. What do I do now? I think I have enough in my can for at least one more s&s coat. 2 more would be iffy. What's my process now? Thanks, I know this has been addressed, I just couldn't find it. |
Level out the run with 400 grit, wet. I can even knock down runs in clearcoat, the trick is to mask around the run so you don't burn through. The other trick is to use a small semi-soft sanding block. The rigid foam sheets used for instulation can be cut into handy little sanding blocks.
Sanding runs on surfaces with compound curves takes practice.
Take it to a tech. |
You could also level it out with a cabinet scraper or a utility knife blade. Don't slice it, but scrape with the blade held almost vertically. You might try putting a piece of masking tape at each end of the blade so the center section rides a little high.
Got this one taken care of. The run was very minimal once it dried. I did a very wet 600 sand all over and was able to get the run out without taking too much out of the sand/seal. Then I just followed up with 2 more coats s/s before going to color....
On to the next debacle... See "lint in nitro".... |
| Reranch Alcohol Dye Assistance & Sand n Sealer Rec | PixelMover | Finely Finished | 2 | July 9th, 2009 09:44 AM |
| Can I put too many coats of sand and sealer before final sanding? | Booman | Finely Finished | 0 | June 5th, 2009 02:29 AM |
| My first neck finish. Wet sand vs. dry sand? | jguitarman | Tele-Tech | 5 | March 18th, 2008 07:25 AM |
| From Sand & Sealer to Blond...wadda I do? | newtwanger | Tele-Tech | 3 | January 30th, 2008 06:02 PM |
| My first finish project (sand sealer done?) | robbysturgis | Telecaster Discussion Forum | 5 | November 5th, 2007 11:32 AM |
