Mcfadden sealer and nitro help.
Hi, I'm about to start spraying mcfadden sealer and nitro, but I have no clue what pressure to spray at. My regulator is fully adjustable and my spraygun manual says to spray at the lowest setting that the manufacturer reccomends, but the manufacturer has no reccomendation!
Be aware that the hose is flexible and it gives a little bit so it acts like a regulator over its length so you may lose 5 or 10 psi from the compressor to the gun. If you have a regulator that you can put at the end of the hose then shoot for (no pun intended) 35 psi to start with.
| Removing Nitro Without Damaging Sanding Sealer | GoodwillHunter | Finely Finished | 9 | September 17th, 2009 03:22 PM |
| BIN Primer Sealer & Nitro Clear | debrad | Finely Finished | 15 | August 7th, 2009 07:38 PM |
| Sanding sealer over nitro??? Refinish | joinpobob | Finely Finished | 1 | March 20th, 2009 02:21 AM |
| McFadden VS. Lawerence-McFadden | jrechin | Finely Finished | 1 | January 31st, 2009 04:45 PM |
| Do you need to use sanding sealer w/nitro? | robt57 | Tele-Tech | 6 | July 21st, 2008 01:53 PM |
