Mohawk has a ton of different toners you can use. If you can find a distributor in town they are a 1/4 of what reranch costs. It doesnt take much, can probably do 20 necks with one can. Then just apply a clear coat. Alot of people like to use Tru-Oil as well.
http://www.mohawk-finishing.com/cata...asp?ictNbr=170 http://www.mohawk-finishing.com/mhk_...or%20Chart.pdf |
This one was finished with Reranch Tinted Clear, followed by several coats of Deft Clear. You have to go easy with the Tinted Clear or it will go past amber to an orange-ish color.
![]() I've done several necks this way and have been very happy with the results. Ciao, Rick |
#5 (permalink) | |
What's the prep required on a shiny sticky fender neck prior to tinting?
It doesn't mean a thing if it doesn't have that twing! |
I mix my own now but the light walnut is pretty good, so is amber but they get dark quick. You need very light coats. Best would be to see actual colour samples in the store. The catalogue samples arent very accurate. You can just grab a few colours and see what you like. Good thing is if you screw up it's very powdery and comes off with just a little steel wool.
Tonemonkey, you can just dull the finish with some 0000 steel wool. |
#8 (permalink) | |
Ciao, Rick |
You might need a business account to deal with them from what I heard.
When I called them the woman told me I could just drop by the show room and buy or order what I need. All though the show room is not open on weekends which leads me to believe the "public" is not that welcome? Gary |
#12 (permalink) | |
#14 (permalink) |
http://www.mohawk-finishing.com/dist_lookup.asp
They have 2 different types, dye based, which lets the grain show thru http://www.mohawk-finishing.com/cata...asp?ictNbr=171 and pigment based, which covers more http://www.mohawk-finishing.com/cata...asp?ictNbr=170 I've used their amber dye based on a curly maple neck after 2 coats of sanding sealer, use light coats & keep it moving. Stop, take a break after the light coat, let it set up & then decide if it needs more. Don't ask how I know this. BTW, laquer thinner on a rag takes this stuff right off if you happen to spray on too much. |
While finding something on their website can be daunting, I have had good experiences with Pond Cove Paint.
#16 (permalink) | |
#19 (permalink) | |
Amber Shellac - just spray a foot away. Check out my white neck Hwy One in my photos.
Play one wrong note and its a mistake. Play two wrong notes and its Jazz. |
#20 (permalink) |
Once the lacquer has gotten really crispy, I make a fret leveling tool similar to what Mr. Ron Kirn does, and clean off and level the frets in a single operation. Before you apply the finish in the first place, you can use a "Q-Tip" coated in wax to carefully rewax (release agent) the frets after the rest of the neck was fully cleaned and deglossed. If you remember to do that, the lacquer comes off the frets pretty easy.
I used to layer the toner on heavy for a dark result, and it meant the neck looked stupid for weeks while I waited for the lacquer to dry enough to fool with the frets. Now I: Go easy with the coating; Hit the fretboard surface at a perfect 90 degree angle for less "penumbra" effect; Don't try to shift the tone of the maple so far; and Have enough other projects on tap that necks can sit up untouched for a month or so. And do that wax thing. If the lacquer is still tacky when you start to flake it off, it will re-adhere like freckles, here and there all over the face of the fretboard. Time this removal process far enough along to avoid this mess. Nothing wrong with installing the neck and playing it with toner on the frets. Just looks goofy, that's all.
When i listen |
#22 (permalink) |
VENDOR
Do not use shellac on a guitar, it doesn't handle moisture well at all.. by moisture I mean the light perspiration from laying your arm on the body as you pick, and of course, the overt sweating from playing in hot. stuffy bars, but no boy play in them do they?
Ron Kirn
www.ronkirn.com |
#23 (permalink) |
ive personally used
amber shellac in clear laquer this.works just fine and will dry rock hard unlike plain shellac witch deems to stay kinda soft. i do live in south texas and it is usually pretty hot down here though. so paint tends to dry pretty quick,hey maybe thats why im always thirsty as well?
#24 (permalink) |
Shooting reranch amber over reranch nitro clear gloss.
Hi I hope it's ok to hijack a bit,
I am in the process of finishing my first vintage style allparts neck. I am using reranch nitroclear gloss and reranch tinted Fender amber. The process I am following is shooting 7 coats of clear and I want to sandwich a layer of amber tint between the base and final clear. Questions I have: 1. Should I level/sand out my base clear before tinting with amber? 2. Should I lay wet clear prior to tinting with amber to allow give my amber better adhesion? 3. I live in a warm 70's, relatively moderate climate (no rain in months). How long should I wait after the last coat of clear before sanding? Thanks, -Mike |
#26 (permalink) |
1. Only if you have any imperfections. You should spray the amber before the clear. Less chance of sanding thru and it will give you more depth as well.
2. No. Lacquer will melt into each previous coat. 3. Depends on how thick the coats are and how much time passed between coats. If it starts to roll up when you sand instead of forming dust or if you can leave a mark when pressing with your fingernail it's still too soft. |
#27 (permalink) |
Thanks Shepherd for the pointers :-)
I am spraying 3-4 times per day, and waiting 60 or more minutes between coats. I waited 9 hours b/t the 4rth and 5th coat, and I am on coat 7. Going thin, but looking for wet coverage. I see dimples, but am assuming that after many coats I'll have enough down to be able to level it in the final stage. These is just with 7 layers of clear only. ![]() ![]() ![]() ![]() Thanks again, Mike |
#28 (permalink) |
Looks like your holding the spray can too close while spraying. It takes alot of sanding to get those out. You might want to give that a light sanding now to make it easier later, and watch out sanding the edges, then a couple more coats. If you place the can in some warm water first it will help the lacquer to flow out smoother.
#29 (permalink) | |
Thanks, Mike |
#35 (permalink) |
I have to say again, I am grateful for posting bad pics, and getting quick and honest feedback. Shepherd being the first. I can't imagine getting 12+ coats in to finally realize I blew it at the first coat. Shepherd, thanks for saving me. and it's seriously OK laugh or wince at this attempt. I own it, and can take it. It's obviously a new process for me, and that's why I am here doin it. Fernando, thank you for the nice words bro. This is after using wool lube and nearly sanding wood. It really felt smooth. If I were finishing a pool cue, I would love for it to have feel that this neck has in the last pics. -Mike |
#36 (permalink) |
If you like the feel of the neck now, here's a tip that will put a permanent smile on your face. After the final coat and it's sanded smooth, take some 0000 steel wool and use it to apply wood paste wax to the back of the neck or the whole thing if you like. Just work it in like your sanding the neck and then buff it out with a rag. The more you buff it the slicker it gets. Mind you the steel wool does leave fine scratches but if you go with the grain they aren't too noticeable.
#37 (permalink) | |
Neat Shepherd! I'll pick up a can of wood paste wax. Thanks again :-) -Mike |
#38 (permalink) | |
The neck looks gorgeous, and I'm sure you are too! See? I can be weird too.
#39 (permalink) | |
I think my neck, looked like cheap cheese pizza. See ya, -Mike |
| TruOil neck or Vintage Tint Clear Coat neck? Show me yours! | PixelMover | Finely Finished | 35 | July 20th, 2009 11:55 AM |
| Neck Tint on a Glossy Neck (Satin Tint First, or Spray Amber?) | markesquire | Finely Finished | 1 | June 30th, 2009 01:05 AM |
| Spray Poly With Tint? | PJ | Telecaster Discussion Forum | 4 | May 9th, 2008 07:37 PM |
| New Neck Tint? | Musicman1 | Tele-Tech | 11 | March 5th, 2008 01:21 PM |
| OK to spray laquer on pickup cover? | jjmantele | Just Pickups | 0 | November 12th, 2006 03:30 PM |
