solid Color Finish Questions?
Ok..I am starting my second build. This one will be an alder body with stewmac solid color laquer finish. I have a few questions:
1) Do I have to use grain filler on the alder for solid color finish 2) Do I need to spray a primer on before color or can I just use sand & sealer or clear laquer coates and then spray color coats without primer? 3) If I do need a primer which product or brand do you guys use? 4) Should I have blush remover, laquer retarder on hand? thanks Keith |
#2 (permalink) | |
Super Moderator
Here's my version of some answers...
"If you can't say something nice... don't say nothing at all." - Thumper the Rabbit "She's not only merely dead, she's really most sincerely dead." - The Munchkin Coroner |
The color is going to be a Solid Dark or midnight blue. I am in Long Island NY.. I will be spraying outside...Humidity is starting to come down...So i am hoping blush won't be a problem. I have a good spray gun and compressor and my skills are pretty good so I hope to get nice even,flat coates.
#4 (permalink) | |
You didn't plan to fail, you failed to plan. |
Ok...I actually looked around some boxes in my shop and found 2 cans of reranch white primer. I was ordering sandpaper so I added blush remover to the order. The Alder has a few areas of grain that I suspect might be a little open so I am going to use oil base grain filler.
thanks Keiths |
ALWAYS! Sooner or later it will save a finish from having to be sanded down. What's the expression? "Better to have it & not need it than to need it & not have it"
"Progress is not possible without deviation from the norm." Frank Zappa |
