Wilde Pickups by Bill & Becky Lawrence Simmons Amp Repair Lace Music Products Acme Guitar Works GuitarSale.com Hahn Guitars Warmoth.com
Old August 10th, 2009, 06:34 PM   #1 (permalink)
How to remove sharpie marks from nitro finish?
Hi guys, I just stepped into the tele world with a Trimmed&Burnin' tele. Love the guitar, but it was signed by a young band before it was raffled, and I'd like to see the wood, not a bunch of names I don't know. It's nitro finish and Shannon suggested rubbing compound. Do you guys have any preferences? Shannon signed it too and I'm keepin' his name on there. This is a great website and I'm already learning a lot. Thanks. mouse
mouse116 is offline   Reply With Quote
Old August 10th, 2009, 07:14 PM   #2 (permalink)
Goo away or just bath room variety alcohol might get it with out eating lacquer...
Some clear coat cleaning compound is really fine, that should take it off and polish the top at the same time.
Hackguitarist is offline   Reply With Quote
Old August 11th, 2009, 09:13 AM   #3 (permalink)
mr.clean magic eraser and a bit of rubbing. my daughter sharpied my hardwood floors and the eraser did the trick.
dlabstudio is offline   Reply With Quote
Old August 11th, 2009, 09:34 AM   #4 (permalink)
otaypanky's Avatar
I have a Gibson LP that Les autographed on the back. I tried to remove it. and soon after it was on there, not years later. Uh-uh, not going anywhere ~
That marker had penetrated deep into the finish. Light polishing compounds, etc., had no effect other than to lighten and make the autograph looked aged.
I hope you have better luck than I did
otaypanky is offline   Reply With Quote
Old August 12th, 2009, 12:01 AM   #5 (permalink)
Well guys, no luck so far. Goo gone at least faded it and crest did nothing except make the denatured alcohol mark disappear, which is a good thing. I may work the goo gone a little more or try some actual compound. The marks have been there for a month, so they may have leeched in. The battle goes on! Be Blessed. mouse
Old August 12th, 2009, 12:27 AM   #6 (permalink)
Al Watsky's Avatar
I have had to "remove" signatures on many guitars.
Lots of "G" brand and Fenders.
If compound won't get it ,you can try wet sanding. Starting high grit. Say 800 , do a small spot. You can get lucky and get most all of it off sometimes. If it seems to lay on the surface you might even start with 600 grit.
Once you fade it as much as possible you just buff it back up to 2000 and then a glazing compound.
On Poly it just comes off. No problem. Acetone removes sharpie from Poly finishes easily. to test the finish use a q tip on a hidden area say in the cut away area to see if the finish reacts to the acetone. You can also use Naptha and alcohol . with varying degrees of success '
Livin' in the Past ,Present and Future
is takin' up all my time..........
Al Watsky is online now   Reply With Quote
Old August 12th, 2009, 12:28 AM   #7 (permalink)
That magic eraser thing is a really fine grit sandpaper. Be prepared to use some rubbing or polishing compound after you're done, if you go this route.
tacodog is offline   Reply With Quote
Old August 12th, 2009, 12:18 PM   #8 (permalink)
boris bubbanov's Avatar
Some of these markers use an acetone, m e k or xylene agent (that's what you smell when you pull off the cap) and that stuff can be real aggressive about weeping down into the finish.
I've seen some AV57s and 62s with deep through stains down (and up) into the lacquer. You'll be removing a lot of finish and yet little may change, appearance wise.
You didn't say if the finish was clear, toned, or bursted. The only thing that always works is removing all the lacquer, or relacquering the guitar in the color of the sharpie, or a darker color.
I used to use a dark marker to place screw holes, strap button holes on lacquer bodies but I stopped doing that - a stray mark is too easy to create.
Old August 12th, 2009, 12:44 PM   #9 (permalink)
guitarzan13's Avatar
Just wondering..... who signed it??
Practice make permanent!!!!....Perfect practice makes perfect!!!
Chris B.
www.neonjones.com
guitarzan13 is offline   Reply With Quote
Old August 12th, 2009, 04:17 PM   #10 (permalink)
The real question here is why were you trying to remove a Les Paul signature? That seems like a pretty big deal.
eric_o is offline   Reply With Quote
Old August 13th, 2009, 04:28 AM   #11 (permalink)
I was wondering about that too. Please tell us why?
Thundersleet is offline   Reply With Quote
Old August 15th, 2009, 07:06 AM   #12 (permalink)
JasonRobert's Avatar
why on earth were you trying to remove his signature????
JasonRobert is offline   Reply With Quote
Old August 18th, 2009, 11:20 PM   #13 (permalink)
Thanks for all the input
Thanks guys. This tele is light pine with clear nitro finish,so the names may just stay there. I can't see taking her out of service long enough to refinish. The band was a young country band called Tumbledown that played in an all day benefit concert. They're pretty good, just not who I'd choose to be on my tele. I'll post if I can figure anything out. Be blessed. Wish I had a Les or Leo signature!
Best way to remove shellac from nitro finish? schoolie Finely Finished 4 April 21st, 2010 02:28 PM
How to remove nitro finish... flapjack Tele-Technical 18 December 12th, 2008 08:40 PM
I Have Figured Out How To Remove Sharpie Autographs! goldtopper Tele-Technical 7 August 27th, 2008 06:02 PM
Capo marks on nitro maple neck? roadrider502 Telecaster Discussion Forum 4 August 3rd, 2008 05:04 PM
Can you get a Sharpie signature off a Nitro finish? Steve McGinnis Bad Dog Cafe 19 December 22nd, 2006 02:58 PM
