How do I protect the ink on an autographed guitar? - Telecaster Guitar Forum
Old July 15th, 2009, 04:37 PM   #1 (permalink)
Ericdb_1's Avatar
I've got a guitar that was signed by Alex Lifeson & a couple of other folks years ago. I'm getting back into playing again after years off & would like to use this one. Is there a coating that would be recommended to put over the autographs, preserving them, that won't affect the finish or quality of the sound? I was thinkning about a spray polyurethane or something and thought I'd better ask before I do something ruinous.
Ericdb_1 is offline   Reply With Quote
Old July 15th, 2009, 05:02 PM   #2 (permalink)
garytelecastor's Avatar
I would love an answer to this question too.
"The world will not be destroyed by those who do evil, buy rather by those who do nothing to stop it"-Einstein
Redd Volkaert is a Master Jedi at one with the Force!!!
garytelecastor is offline   Reply With Quote
Old July 15th, 2009, 05:10 PM   #3 (permalink)
Is the signature on the pick guard or the guitar finish itself?
If it is on the guitar finish, is the finish poly or is it nitro?
homerzeppelin is offline   Reply With Quote
Sponsored Links   #
Old July 15th, 2009, 06:10 PM   #4 (permalink)
You should use a coat of lacquer...probably acrylic instead of nitro.
This demo displays someone applying decals to guitars and he talks about protecting them with a coat of lacquer afterwards...slightly different topic, but essentially the same purpose.
http://www.youtube.com/watch?v=ApMJE2PuzNQ
lamotta77 is offline   Reply With Quote
Old July 15th, 2009, 07:31 PM   #5 (permalink)
Papa Joe's Avatar
I would do a test run before using lacquer.That stuff eats some things..If it was mine I would use clear enamal..
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body,but rather to skid in broadside,thoroughly used up,totally worn out,and loudly proclaiming:"WOW,what a ride!"
Papa Joe is offline   Reply With Quote
Old July 16th, 2009, 01:10 PM   #6 (permalink)
originalmatthew's Avatar
if it's for protection only, and you dont mind how it looks, you could use transparent vinyl sheets like the ones that they make window signs out of that you can put on and reuse.
Let someone else do the white paint job!
originalmatthew is offline   Reply With Quote
Old July 16th, 2009, 01:15 PM   #7 (permalink)
repeatofender's Avatar
+1 that wont melt the ink.
repeatofender is offline   Reply With Quote
Old July 22nd, 2009, 08:55 PM   #8 (permalink)
jimd's Avatar
Do you know what they signed with? Was it a Sharpie? I would test whatever you want to coat it with on the same type of ink used to autograph it.
If the autographs are reallly important to you, I honestly would think about retiring that guitar. A job like this could really end badly. If the signatures are on the pickguard, swap it out. If they are on the body, I would pick up a replacement body on ebay and swap that out.
jimd is offline   Reply With Quote
Old July 30th, 2009, 05:52 AM   #9 (permalink)
salamatizm's Avatar
On nitro:
You can buy transparent water slide decal paper... cut out the shape of the signature and apply it like you normally would a waterslide, then you can coat with nitro...
Sand with fine grit then polish with a rubbing compount. You wont see the decal at all.
It will be like the signature is under the finish!
Nitro never cures and if you would spray nitro over a signed spot without covering it with something transparent, it would most def melt your finish (and signature).
Here you can find a description on how to apply waterslide decals to your favourite nitro finished guitar:
http://relicdeluxe.com/decal_instructions.asp
Here you can buy decal paper, be sure to get transparent paper, not white:
http://www.decalpaper.com/category-s/2.htm
On poly:
I would just apply a clear vinyl sticker, and not coat with lacquer or anything. Don't you date come near a nitro finished guitar with vinyl decals, stickers!! :o)
salamatizm is offline   Reply With Quote
» Random Photo for Guests
Gibson Les Paul Studio
» Recent ThreadsGuests
Fender Logan Custom Guitars
