Old April 13th, 2009, 02:00 PM   #1 (permalink)
neck finish : coats on top of satin finish ?
Hi folks, I just got this nice WD all maple neck with a dull satin finish.
I want a slightly more dark color and a bit more shine. How would I do that ? Do I need to remove the satin finish first ?
I've searched through the forum but there are many approaches, I'm just looking for easy tips.
I was thinking of applying some polyU water based minwax coats mixed with some tint, and finish it with a light gloss. I think Rob DiStefano posted something along these lines.
thanks !
zigaboo is offline   Reply With Quote
Old April 14th, 2009, 10:57 AM   #2 (permalink)
gotdabluz's Avatar
You don't have to completely remove the finish to apply a gloss top coat over it . . . you will need to sand down some though (400 grit would be sufficient), in order to provide some adherance for the new finish
You will likely not get the 'full depth' that is possible with a 'pure' gloss from start to finish, but the results can be more than satisfactory
I have 'refinished' two Mighty Mite necks (which come with a dull satin finish), with excellent results using Minwax Wipe-On poly . . . I actually used the clear satin as opposed to the gloss . . . once you finish buffing it out, it is still quite glossy (especially if you to your final buff with something like Meguiar's Scratch-X) . . . I find it looks a little more vintage and not so plasticky as the clear gloss poly does
Be forewarned though, that 'refinishing' a neck with wipe-on poly is a time consuming process - especially with a fretted maple fingerboard (the prepwork is very tedious) . . . I did both of my necks during the winter when other finishing environments (outdoors/unheated garage) were not available . . . and . . . I was not in a hurry, so I did not mind spending the time it took to complete them.
It would be much easier to spray them with a tinted lacquer (like reranch sells) . . . I have never tried to tint wipe on poly, but I suppose it would be possible if you used a water based dye and waterbased poly for base compatibility . . . if you end up going this route, then I would recommend testing first on some scrap maple . . . You might also want to first get your tint base the way you like on the neck and then topcoat with clear for protection
Best of luck,
'Bluz
gotdabluz is offline   Reply With Quote
Old April 14th, 2009, 11:58 AM   #3 (permalink)
thanks a lot, that really helps !!
Old May 2nd, 2009, 08:44 AM   #4 (permalink)
fernando's Avatar
gotdabluz: thank you for the info. How do you apply the Minwax WipeOn? With a cloth? Will it came out of the frets later?
fernando is offline   Reply With Quote
Old May 6th, 2009, 07:40 PM   #5 (permalink)
telecster's Avatar
Same question here but I would like to put a Butterscotch finish on the neck and fretboard.
telecster is offline   Reply With Quote
Old May 7th, 2009, 05:47 AM   #6 (permalink)
Shepherd's Avatar
It's alot less work and you will get better results just using some spray toner and lacquer. They have an amber toner and it's available in Montreal.
http://www.mohawk-finishing.com/catalog_browse.asp
Neck Finish: Satin vs. Sanded Lacquer markesquire Tele-Tech 3 March 26th, 2009 08:34 PM
De-glossing a satin neck finish Del Pickup Stratocaster Discussion Forum 8 November 11th, 2008 09:51 PM
How to degloss a satin finish neck that's gone shiny? Del Pickup Stratocaster Discussion Forum 11 September 10th, 2008 12:12 PM
Krylon Satin Neck Finish FatBack Tele-Tech 15 April 19th, 2006 09:47 AM
Changing satin finish to gloss on mm tele neck chubbyjackson Tele-Tech 12 October 19th, 2004 05:06 PM
