Old March 7th, 2009, 10:04 PM   #1 (permalink)
Staining Mahogany
I'm thinking of bleaching a mahogany body that has a cherry stain on it, similar to a Gibson Faded SG. I want to bleach it to a lighter color and stain it a Emerald green color.
After using a two part bleach and sanding do I have to use a grain filler or sealer prior to staining? I've painted a guitar before but never stained one. Thanks
Alldimarzio is offline   Reply With Quote
Old March 8th, 2009, 08:04 PM   #2 (permalink)
Anyone?
Old March 8th, 2009, 08:31 PM   #3 (permalink)
steve gibson's Avatar
You can buy wood bleach at Menard's, etc. It is easier on the hands, eyes, lungs and wood. It depends on what kinds of finish you are after regarding the grain filler. If you want a smooth glassy finish use filler. I usually use shellac to seal before staining. Two light coats with a cloth and sanded smooth. The stain will take more evenly, esp the end grain.
Buildin' and Playin'
steve gibson is offline   Reply With Quote
Old March 8th, 2009, 10:01 PM   #4 (permalink)
I've had real nice results sealing wood with shellac prior to staining. I would add only one more point regarding the end grain. Sand it to at least one higher level than what you're using for the faces. If you go down to 180 or 220 on the faces then use 400 on the ends. Use whatever grits you like, but the point is that end grain still absorbs more stain than the face, sand it smoother and seal with shellac and you can obtain completely even results.
Peter
Ranger is offline   Reply With Quote
