Old March 7th, 2009, 03:33 PM   #1 (permalink)
Muddslide's Avatar
Refinishing with binding...
Years ago I used to do quick-and-dirty refinish jobs on lots of guitars. Really enjoyed it. My work looked good, but I did a lot with Formby's stripper, sandpaper and rattlecans of primer, paint and clearcoat.
I have this el-cheapo Tele copy I am considering refinishing, but it has top binding. I'd like to preserve it, but I've never re-done a guitar with binding.
Should I just get a special kind of tape, mask it off and make sure no chemicals or paint gets to it?
Thanks for any pointers.
Muddslide is offline   Reply With Quote
Old March 7th, 2009, 03:56 PM   #2 (permalink)
I know lots of folks tape their binding, but the traditional way is to scrape it with either a curved blade or piece of broken glass.
The reason for the curve is so that you can avoid a sharp transition line between the painted and unpainted regions over your binding. Grip your scraper between your fingers, and run it around the perimeter of the guitar, using your fingers/hand as a "fence" to keep your scrape line uniform and equidistant from the edge of the guitar.
Scrape after each color coat, then clear over the whole thing.
Chris Leger is offline   Reply With Quote
Old March 9th, 2009, 09:55 PM   #3 (permalink)
shadowfan's Avatar
Isn't there a chance that, if plastic, the binding material may be damaged by the paint if it is solvent based?
Eternity seems like a long time, especially towards the end
shadowfan is offline   Reply With Quote
