Old April 30th, 2012, 09:17 PM   #1 (permalink)
borismcorpheus's Avatar
"Refinish" a pedal with duct tape?
I just got a Joyo Ultimate Drive and pretty much hate the paintjob. Creeps me out a bit
Anyhow, seeing as how I don't really have the time or desire to spend money on actual painting supplies and also since I have quite a stash of colorful duct tape available, I was thinking about doing some duct tape art on the pedal enclosure right on top of the pre-existing paint.
Has anyone ever tried something of this nature? Is it worth putting clear coat or something on top of the tape?
Thanks in advance. BTW, I'm a TDPRI semi-lurker (joined but never posted much) who is a regular over on Strat-Talk, so a shout out to anyone here who is also a regular there!
borismcorpheus is offline   Reply With Quote
Old April 30th, 2012, 10:37 PM   #2 (permalink)
TNO
You could also just sand the top down to bare aluminum.
TNO is offline   Reply With Quote
Old May 1st, 2012, 09:32 AM   #3 (permalink)
I thought of that but figured it would probably look nicer if I put something on it. My sanding job would probably have been rather sloppy :P
Old May 1st, 2012, 03:09 PM   #4 (permalink)
I've never seen a duct tape finish on a pedal, but Ibanez had a duct tape Talman that they released a while back. I think it was Noodle's signature model (from the Offspring). I think the same finish would look pretty cool on a pedal.
I remember reading a tiny bit how they did the finish, there's definitely a clear coat of poly over the duct tape, AND, I think they sprayed some black who-knows-what (probably more poly) on it and then wiped it back off to accentuate the texture of the duct tape even more.
joe_mcdogwad is offline   Reply With Quote
Old May 7th, 2012, 12:26 PM   #5 (permalink)
So I did it with duct tape. Pretty simple, a little rough, but that's all part of the charm right?
Old May 7th, 2012, 01:35 PM   #6 (permalink)
Lost_N_Austin's Avatar
Sure why not try it
I tried removing the finish on a TU-2 pedal that had been spray painted Lime Green and I could not get to bare metal with conventional means. I think that some are Powder Coated and that stuff really sticks. Why not try these?
Just Google Duct tape designer images
Take a picture of it before and one after and then post here or it didn't happen.
Lost_N_Austin
Is this the real life? Is this just fantasy? - Freddy Mercury
Lost_N_Austin is offline   Reply With Quote
Old May 8th, 2012, 07:38 PM   #7 (permalink)
Nice! That looks great. Did you put a clear coat on over the duct tape?
Old May 8th, 2012, 07:49 PM   #8 (permalink)
burtonfan's Avatar
If you use the "classic" silver, it'll resemble my truck!
He who claims, "...she won't let...", seriously needs to grow a set!
burtonfan is offline   Reply With Quote
Old May 12th, 2012, 03:02 PM   #9 (permalink)
No clear coat... too lazy and cheap to go out and buy the spray and sandpaper and stuff :P
