Old December 21st, 2011, 04:34 PM   #1 (permalink)
Guit-jitsu's Avatar
Distortion by component type - help!
Sorry if this has been discussed before, but I couldn't find what I'm looking for with the search. There are so many OD / Distortion / Fuzz pedals and clones out there, I thought it might help me make sense of them all by understanding the components used to create the distortion.
For example, I know that fuzz is generally created with either silicon or germanium transistors? And the classic TS style OD is from an Op-Amp? What other examples are there, and can you effectively 'sort' distortion types by component?
i.e.
Germanium transistor >> Fuzz Face & similar
Silicon transistor >> ??
Op-Amp >> Tube Screamer & similar
Diode clipping >> ??
FET, JFET, etc. >> ??
others?
Appreciate the input!
The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, “You know, I want to set those people over there on fire, but I’m just not close enough to get the job done.” - George Carlin
Guit-jitsu is offline   Reply With Quote
Old December 22nd, 2011, 10:59 AM   #2 (permalink)
Guit-jitsu's Avatar
bump ...
sorry for my ignorance on this stuff. Is this a good way to understand distortion pedals or am I barking up the wrong tree?
Old December 22nd, 2011, 11:01 AM   #3 (permalink)
paratus's Avatar
Fulltone GT-500 uses MOSFETs and FETs. In typical circuits they do all sound different.
Semper Paratus
paratus is offline   Reply With Quote
Old December 22nd, 2011, 11:35 AM   #4 (permalink)
FosterF's Avatar
Although TS type pedals so rely on an OP-Amp they also rely on diodes for the actual clipping.
I do believe the Fulltone Fulldrive uses 1N34's and LEDs
The ibanez tubescreamers use 1N4148s
FosterF is offline   Reply With Quote
Old December 23rd, 2011, 05:23 AM   #5 (permalink)
GM Arts has an article called "Overdrive & Distortion" with descriptions of classic designs.
limbe is offline   Reply With Quote
Old December 23rd, 2011, 10:46 AM   #6 (permalink)
DrewB's Avatar
Silicon transister - Colorsound Overdriver
There is no substitute for Sound Pressure Level
DrewB is offline   Reply With Quote
