ROSS FLANGER circuit: AC lineage?
Hey,
I have a viontage ROSS Flanger pedal which has had the AC cord cut, and an extension cord rigged onto the remaining wires to allow it to be used again. I want to confirm that the extention is wired correctly now, as well as obtain the information to replace the original AC cord completely with a new one.
Since I am illiterate schematically etc., I need a photograph of the AC connections inside the pedal.
Recent experience with vintage amps has shown me that circuits still function/produce output when the AC wiring is reversed. This is hazardous to people at a minimum, and likely to tone and componenets. While the pedal sounds good and has no excessive noise, I have had some difficulty using a Radial effects loop/mixer true bypass box with it; the 0 - 180 degree polarity switch is adding extra variables, and I cannot seem to be able to obtain the exact tone of the Flanger alone with the true bypass/mixer box currently.
If someone has an old RED Ross USA Flanger they are willing to photograph the AC connections inside the pedal, I would be much obliged and appreciative! Perhaps there is a picture available online alreasdy which I have missed in my searches?
RRrrrATTA..TAT..TAT Thomas
