Adding High/Low Pass/cut to the Splitter Blend
I'm going to make a Splitter/Blend pedal to parallel some effects on my board.
![]() I could either build it into the SplitterBlend or add an EQ pedal into each chain. Are there any suggestions out there for an active EQ I could build into the Send circuit pref around a MPF102 (I have a few) Any help appreciated |
Have a look here for some EQ ideas.
http://www.geofex.com/article_folders/eqs/paramet.htm |
Cheers Jeff
From your link: ![]() This sounds like an interesting alternative to a traditional EQ! A notch filter with variable freq and width; that could work sweet. I could use three TL072 to build the two channels, or possible swap out the first buffer for a MPF102 Tillman preamp type circuit! Thoughts? Has anyone tried this type of circuit in anger? |
Here's a schem of an eq pedal I designed. There is one knob to adjust the bass/treble balance similar to a big muff tone control, and one knob that actively boosts/cuts the center frequency. The center freq is set with a switch at 400hz (Fenderish), 650hz (Marshallish) or 1000hz (Voxish). If I remember right, I set the mid boost/cut at about +8db/-16db, and it gives a very usable range of tones. The last op-amp is a gain stage that also mixes an auxiliary input to connect an mp3 player or something.
It makes for really simple controls but also very effective. I made a layout for it on vero, if you're interested.
Thanks tjk; that looks interesting.
I think What I'll do next is build the Original SplitterBlend as shown at the top and get that working on Vero; Then I could quite easily jump off the Vero just after the buffer at the splitter stage and try some EQ ideas out on breadboard. I think that would work quite well on this build. RE the original Circuit at the top: are the 10u Electrolytics used to decouple the output stage overkill? Assuming an output z of 1M from the splitterBlend and an Imput Z of 1M for the next device. total Z would be about 500K. F = 1/(2*Pi*R*C) = 1/(2*Pi*500k*10u) = 1/31 = 0.03 HZ I'd rather use some of the polyprop caps I have; I have 4u2, 2u2, 560n, 470n, 330n and on How low do you think I could safely go? |
