Old April 16th, 2011, 06:44 PM   #1 (permalink)
M9 / M13 expression switch? Looking for diy info
I did a search but I'm not sure exactly what they're called. I'm looking to build a switch that allows me to change expression settings for a preset on my M13. Basically a switch to use in place of an expression pedal. Any help is appreciated.
Joe Faraldi
http://www.faraldi.com
"Are you ready for what's to come..."
Faraldi is online now   Reply With Quote
Old April 17th, 2011, 06:57 PM   #2 (permalink)
Teleworshipkid's Avatar
Get a boss latching footswitch and plug that sucker in.
A cool effect I have found is to hook up a momentary footswitch (like a keyboard sustain pedal) and set it to control the volume perimeter for a kill-switchy sound.
Teleworshipkid is offline   Reply With Quote
Old April 17th, 2011, 07:02 PM   #3 (permalink)
Sorry, didn't see that you wanted to diy... Oops!
Buy a stomp box footswitch from
http://www.stewmac.com
And an enclosure + jacks + wire from
http://radioshack.com
And hook it up so that the switch connects/deconnects the two pins coming off the jack. Maybe even hook up a battery/resistor/LED setup so you can see if it's on or not...
Old April 17th, 2011, 09:09 PM   #4 (permalink)
Thanks man. So is it really just as simple as a break in a circuit? Is there a need for a small value resistor? ( I know enough to get myself in trouble) :)
Joe Faraldi
Old April 17th, 2011, 09:37 PM   #5 (permalink)
Not entirely sure... It should work. Try by plugging in a cable and connecting the two parts with something conductive, then unconnect them. See if it works!
Old April 17th, 2011, 10:17 PM   #6 (permalink)
Yep, I'm going to give that a try. Thx man,
Joe Faraldi
Old April 18th, 2011, 02:16 PM   #7 (permalink)
ChipOnly's Avatar
I'd like to build a expression control for my M9 that is a just a big ol' knob I could rotate with the side of my foot.
I use an ernie ball 6181 volume pedal as an expression pedal for the m9, which works great. It has a 25k pot. If I just wired up a 25k pot (linear taper?), would that work just as well? Thanks gents!
ChipOnly is offline   Reply With Quote
Old April 18th, 2011, 08:57 PM   #8 (permalink)
Not entirely sure why you would want this, but I guess it should...
Old April 18th, 2011, 09:24 PM   #9 (permalink)
gatimberframer's Avatar
Faraldi,
It's not a simple circuit breaking switch, but all you need to do is put a 10k resistor between the lugs of the switch.
I took an old orphaned peavey three button footswitch, got rid of the middle switch, wired in a couple of 10k resistors, cut the lead to about 2' long and added two 1/4" plugs to the end so I have both expression switches in one housing with built in cable.
I haven't used it yet other than to make sure it works.
ID:	80518   Click image for larger version
gatimberframer is offline   Reply With Quote
Old April 18th, 2011, 10:11 PM   #10 (permalink)
Originally Posted by gatimberframer View Post
Faraldi,
Thanks very much. Dumb question... is the connection of the two wires connecting the tip and the sleeve?
Joe Faraldi
Old April 18th, 2011, 10:59 PM   #11 (permalink)
Yes. There is no where else to put them!
Old April 18th, 2011, 11:23 PM   #12 (permalink)
Told ya! I'm dangerous with a little info.
So when the circuit is off, there's still a connection but it's got that resistor in the way, thus giving the M13 what it needs to function?
Please don't hate me. :)
Joe Faraldi
Old April 18th, 2011, 11:33 PM   #13 (permalink)
Yeah. It has to have a detectable amount of resistance to acknowledge the presence of a pedal.
Old April 18th, 2011, 11:40 PM   #14 (permalink)
Holy cow!!! I think I actually may understand this now!
gatimberframer and Teleworshipkid and all, THANK YOU!!!
Now to build.
Joe Faraldi
