Old March 15th, 2011, 04:58 PM   #1 (permalink)
BYOC-Confience booster Mod
Hi all i have recnetly purchased a confidence booster from BYOC to quick start some soldering projects.
I was wondering what i need to get to make it a full functioning pedal with an LED and dc power input wiyth everything else.
does anyone have a list and a schmatic for wiring it.
Many Thanks
Ed.D.R is offline   Reply With Quote
Old March 15th, 2011, 05:18 PM   #2 (permalink)
ToadLC's Avatar
You will need:
Enclosure
3PDT switch
Mono jack
Stereo jack
9V battery snap
9V DC jack
Led, bezel and CLR
Potentiometer
Knob
Wiring:
Happiness is not a destination: it is a manner of traveling.
ToadLC is offline   Reply With Quote
Old March 15th, 2011, 06:00 PM   #3 (permalink)
That is fantrastic thanks but what is a bezel and CLR
and also in an unrelated note is there an easy way of checking if you replies to post or do you have to actly click on them and check maulaly.
Old March 15th, 2011, 06:12 PM   #4 (permalink)
ToadLC's Avatar
The bezel is a chrome or plastic piece that holds the LED into a drilled hole. The CLR is a current limiting resistor (it's shown in the layout) without which you would burn out the LED immediately.
The second question I can't answer.
Old March 22nd, 2011, 09:39 AM   #5 (permalink)
HoodieMcFoodie's Avatar
Yes. At the top of the thread on the right there is a little box that says, "Thread Tools". Inside there is an option to "Subscribe to This Thread". You can set it so you get an instant e-mail whenever someone posts to your thread.
HoodieMcFoodie is offline   Reply With Quote
