diy box of rock build questions
i am looking into building a box of rock clone minus the boost circuit. the schematic i am using calls for a 5k reverse audio pot for the gain control. is it ok to use a 5k linear or 5k audio pot instead as i have access to these otherwise i will have to order them everything else for the build i can get locally i think with a few substitutions
A = Audio taper (log)
B = linear taper C = Reverse taper (log) You can sometimes substitute between them. For certain functions and/or circuits you'll need what is specified because it will work best. Here's an article that explains potentiometers and their function. http://sound.westhost.com/pots.htm
Happiness is not a destination: it is a manner of traveling. |
The linear pot is fine in the SHO or "modular SHO" circuits. The reverse audio just gives a slightly better "sweep." But since most folks set the gain (or boost) and forget it, IMO it's not that critical.
