Old October 29th, 2010, 02:19 AM   #1 (permalink)
quick resistor question
So im building a zendrive clone and it calls for a 2M2 resistor. I ordered from the pedalpartsplus a 2.2M resistor. Its the same thing correct?
mlweidl is offline   Reply With Quote
Old October 29th, 2010, 03:45 AM   #2 (permalink)
metulmykul's Avatar
yep!
"Amps should have an on/off switch and a f***king volume and tone. If you get a really fancy one, it should have reverb on/off..."
S.P Jones
metulmykul is offline   Reply With Quote
Old October 29th, 2010, 07:48 AM   #3 (permalink)
HoodieMcFoodie's Avatar
Pretty much whenever you see a letter between two numbers in resistor values the letter is replacing the decimal point.
2M2 = 2.2M ohms
4k7 = 4.7k ohms
3r3 = 3.3 ohms
HoodieMcFoodie is offline   Reply With Quote
Old October 30th, 2010, 08:25 PM   #4 (permalink)
Montana_Dawg's Avatar
The reason for the letter in place of the decimal is because in the past, printers sometimes didn't print the decimal. So when the schematic was scanned or copied, it didn't show up, and it caused problems.
These days, the technology is much better for scanning/copying/printing, but the convention is still used by some people. I have mainly seen this on schematics from Europe. Not so much in the USA except for smaller builders.
I would rather be a jack-of-all-trades and master of none, than be a one trick-pony out of a job.
Montana_Dawg is offline   Reply With Quote
Old October 31st, 2010, 01:07 AM   #5 (permalink)
JohnnyCrash's Avatar
It's the same... where in the circuit does it call for the resistor? If you can't find a 2.2M you might be able to sub a different value in (if it's an anti-"pop" pull down for instance).
3 Gibsons, 5 Teles, assorted other guitars, about a dozen amps, about two dozen pedals, a Smith & Wesson SW40VE, & a .40 SIG Sauer P226R = too many toys, no money, carpal tunnel, and a serious hearing problem.
