Old September 22nd, 2010, 09:35 AM   #1 (permalink)
yonie's Avatar
pedal worked.. until i encased it
I just finished my third pedal build.
I decided something a bit harder would be fun, so I made a Big Muff clone. I had it fully working yesterday on a piece of cardboard. This morning I disconnected everything and put it in it's final case.
Now it stopped working. When switched off (true bypass) all is fine. When I switch on the pedal the LED does power on but there is no sound at all from the circuit. It's dead silent.
Do you guys have any tips on where to start fixing this?
yonie is offline   Reply With Quote
Old September 22nd, 2010, 10:23 AM   #2 (permalink)
Double check all connections first. This happened to me once... I'd forgotten to connect the case to ground (needed to run a wire to one of the ring connections on one of the jacks.
Trout is offline   Reply With Quote
Old September 22nd, 2010, 10:25 AM   #3 (permalink)
Montana_Dawg's Avatar
Start by checking that the transistor pins are correct in the circuit.
One thing to note: you should never work on any kind of paper product, even with transistors. Electrostatic Discharge will damage active components.
I would rather be a jack-of-all-trades and master of none, than be a one trick-pony out of a job.
Montana_Dawg is offline   Reply With Quote
Old September 22nd, 2010, 10:41 AM   #4 (permalink)
yonie's Avatar
Thanks! I was going through the wiring, when I remembered the 3PDT had a suspicious solder joint (came nearly loose while soldering a wire to it) so I tried another 3PDT. To my surprise that fixed the problem!
Thankfully I can quickly close the pedal up, it's become a little bit of a mess in there
Thanks for your help, I'll keep the Electrostatic Discharge caution in mind for my next project.
Old September 22nd, 2010, 10:43 AM   #5 (permalink)
rcole_sooner's Avatar
Check that the circuit is not grounding to the case, where it should not be. Cases are pretty tight and it is easy to get something touching the side that should not be.
rcolesooner's Channel
rcole_sooner is offline   Reply With Quote
