Old April 24th, 2010, 03:27 PM   #1 (permalink)
Ernie Ball Vol Pedal Taper Mod Question
I have pulled out and dusted off my early 90's EB Volume Pedal. This is the older mono model with jacks on the sides. The thing needs a new pot, its hopelessly scratchy which is why I put it away years ago. DeOxit is not helping.
While reading up on the correct pot at the EB web site, I see that the newer models have an internal switch to choose between two tapers. The stock taper on mine is only useful for 50% of the throw - it changes the volume too fast. My question is if anyone who has one of these has looked to see how this taper option is done? Being a passive pedal, I assume the switch puts another resistor into the circuit to change the pot taper, but I am unsure where and what value to use.
Thanks for the help.
notyalcer is offline   Reply With Quote
Old April 25th, 2010, 01:16 PM   #2 (permalink)
Found the answer to my question here, if anyone else is interested.
Old September 22nd, 2012, 05:17 PM   #3 (permalink)
That links no good. Can you point me to a new one? Thanks!
JasonG is offline   Reply With Quote
